Question about Whirlpool WED5800S Electric Dryer
Dryer flips breaker everytime
Everytime the dryer door opens it flips the breaker. I flip the breaker back and the dryer works fine. This has only been happening the last 2 weeks. The dryer is about a year old.
  • 334 Answers
There is a short to ground somewhere.
Most likely where any wires go through the cabinet into the door or inside the door where a hinge or other moving part ir rubbing it.
Disconect power (unplug it) and inspect all wiring close to those areas for worn spots. If you have an OHM meter, you can ohm each wire to ground and see which one is shorted, then trace it back to the problem area.
Posted on Dec 30, 2008
Was working fine. Tried a few days later to dry a load and the starter wouldn't turn load on.
First. Check voltage if its a electric type flip breaker all the way off than back on sometimes breaker flips halfway. Then check for a thermal overload near blower housing usually long and white if it fails motor won't run
Jun 12, 2015 | Dryers
Dryer wont start
Did you flip the breaker to the dryer and flip it back on
That has worked for me
Apr 04, 2014 | Dryers
I have to flip the breaker to the water heater to take hot showers
You need to get the landlord to fix that issue. It sounds like an internal short in the heater.
Jul 10, 2012 | Water Heaters
I flipped the breaker in my fuse box to my dryer off and back on while the dryer was running. now the dryer wont come back on. what could be the problem and is it easy to fix?
if the unit was working fine before you flipped the breaker off then i would say you have a bad breaker... it is possible for only half the breaker to fail and you would still have a light and possible even tumble on dryer but no heat.... turn breaker off again and snap back on may require a few trys and it may require replacement of breaker...obviously the correct way to test would be with a volt meter (ac current) and test at your dryer where it connects are you getting 220- 247 volts on the 2 outside terminal connections... if not your breaker or plug has failed.... good luck to you
Jan 19, 2011 | Whirlpool WED5300S Electric Dryer
We flipped the breakers in our fuse box to do some wiring, when we flipped breakers back--our electric dryer will not start, but the light is on inside the dryer when I open the door
Hello- I would check the dryer outlet and confirm you are getting 220V. As well, flip the dryer breaker on an off again (it should be a double style breaker, 2 singles linked) sometimes they are sticky. Let me know if it still doesn't work. Best regards.
Sep 27, 2010 | Maytag Dryers
Lost power after opening door during cycle.
Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
Oct 29, 2009 | Dryers
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Dryer has power but will not start.
You might have a wiring issue in the dryer or a bad control board.
Feb 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool WED5800S Electric Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
