Question about Bob Mackie Tracktion 2 (663961007589)
Tracktion 2 audio input device problem
When I start up Tracktion 2, i get the following message
Error opening audio device:
Error opening audio output device!
It won't detect my Linksys.USB interface and it refuses to go into icon mode when I choose to edit a track.
Help!
  • Anonymous Feb 05, 2009
    I have the exact same message....even though I have a mic hooked up to output 1 and headphones hooked up to monitors, Tracktion tells me it has an error connecting to an audio device!!!!
  • Anonymous Mar 07, 2009
    same. AHHHH
I had the same problem with this software when trying to install it on Win Vista. After realizing that my attempts were futile,( cuz it wasnt designed for this os and there was no easy fix, other than reverting my machine back to XP ), I stepped out on to my front porch and threw the d*mn disc frisbee style out into the street...at which point a fat little kid picked it up and stuffed it into his back pocket and waddled off happily with his new possession. I wish the little fat bastard lots of luck with it, and hope he has an XP equipped machine to install it on, I'd even give him the product key if he asks for it...LOL
Posted on Jul 15, 2009
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Whenever i tried calling someone and talking then i try to turn on my headset to talk to them from it it doesnt work
. Open up your control panel and double click on audio device properties. There you'll find your device settings for sound , audio , input and output device settings . You will select your headset for your audio and microphone properties . Also , follow the instructions to set up your microphone input levels .
Apr 28, 2011 | Radio Communications
I have a acer with the acer crystal eye webcam built in it. do it have a microphone with it. if so how do I get it to work?
The Acer with crystal eye webcam will also have a built-in microphone. The webcam is in the center at the top of the screen. The built-in microphone is typically half-way between the edge of the screen and the webcam. It is a little opening with a microphone logo beside it. You can test both audio input with the built-in microphone and the audio output with the built-in speakers by doing the following....
1. click start > Control Panel > Sounds and Audio Devices
2. in the Sounds and Audio Devices Properties click the Voice tab, then click the Test hardware button
3. in the Sound Hardware Test Wizard window click the Next button, if required, click unblock...
4. speak into microphone to do the Microphone Test. Recording meter will show movement if it works.
5. click Next button to do the Speaker Test. Microphone input is now output on the speakers.
6. click Next button when finished doing the readings and click Finish to close the wizard.
Mar 20, 2011 | Computers & Internet
No audio output device installed in my dv9815nr
  1. Click Start , type services.msc into the search field, and then select services.msc from the list when it becomes available to open the Programs window.
  2. Grant permission to continue, if prompted.
  3. Scroll down to and select Windows Audio , right-click to open the drop-down menu, and then click Start . Figure 1: Starting the Windows Audio servicec00847914.gif
  4. Right-click Windows Audio , click Properties , and then verify that Startup Type is set to Automatic . The Windows Audio service is now running. The error message should close.
Mar 04, 2011 | HP DV9815NR Pavilion Laptop
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
Jan 20, 2011 | JVC HD-61G787 61" Television
No audio device intalled
ometimes error messages such as 'No Audio Device is Installed' or 'Audio service is not running' occur when opening the volume control by double-clicking the volume icon from the system tray. To resolve the error, follow the steps below.
Oct 26, 2010 | HP Compaq Presario F500 F700 and G6000...
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Problem with this NullSoft directSound output v2.47 (d) error
My long standing WinAmp suddely started giving me the following message: "Bad Direct Sound driver, Please install proper drivers or select another device in configuration. Error code 88780078"
Jul 11, 2009 | Computers & Internet
No Audio Output Device Installed
Hi
To immediately fix these errors in Vista, start the Windows Audio service as follows:
  1. Click Start c00834869.gif , and enter services.msc into the Start Search field.
  2. From the list of services, right-click Windows Audio and select Start . Figure 23: Starting the Windows Audio service c00847914.gif
  3. The message should no longer open. If the message opens again after the computer is restarted, repeat these steps, select Properties for Windows Audio and set Startup Type to Automatic.
If you have XP on the computer, then click Start-->Run and then type "services.msc" in the Run window and then click OK and once you get the Windows Services screen, follow the above steps.
If this doesnt work and the sound card is not onboard or integrated, then reseat the sound card preferably into a different slot and repeat the above steps.
Feb 13, 2008 | E-Machines eMachines Desktop PC
Lost the manual, can't get hooked up
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
May 28, 2007 | TDK DA-3826 2-Disc CD Recorder
Computers & Internet Logo
643 people viewed this question
Top Bob Mackie Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Bob Mackie Computer and Internet Expert? Answer questions, earn points and help others
