Question about Technics SA-DX930 Receiver
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out sound. after looking at them I found that the Technics SA-DX930 worked only in the two surround sound speaker outputs when the receiver is set to surround sound and DSP. But the rest of the speaker outputs don't really work, other that if you turn the receiver all the way up and you get right next to the speaker, then you can very very very faintly hear the music. So faintly it is like it isn't even there. The display works and everything else works I am just stumped on what might be the problem.
You blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Posted on Apr 30, 2007
Would I be able to connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
Yes, it is hooked up using the (cassette) tape inputs and outputs. Use the tape monitor switch on the receiver to switch the EQ in or out.
Feb 11, 2016 | Panasonic Technics Sa-dx930 A/v Stereo...
Connecting sub speaker to technics sa dx930
Yes, if it only has speaker-level inputs it would require an amplifier to properly drive it. Name the sub and maybe we can answer the second question.
Mar 28, 2010 | Technics SA-DX930 Receiver
My technics sa-dx930 receiver stops working and an error message is displayed that says "overload" when i use the "b" speakers for my patio. This is a new problem. i have had the same outside speakers,...
Hey, I own one of these systems. Whenever I touch two of the wires together (shorting it out) the system shuts down and overload appears on the display. My suggestion is too check your wiring (especially in the spliced areas) or replace the wiring to the outside speakers and try it again. If you dont want to try that, take the wires you have hooked to the A speakers and see if they will work on the B setting (a quick troubleshooting technique). Please let me know if it worked for you. Good Luck!
Sep 09, 2009 | Technics SA-DX930 Receiver
Can I hook up an X box to a technics SA-DX930 and a Hi def TV
Yap, as long its supported with a high definition 1080P.
Jul 24, 2009 | Technics SA-DX930 Receiver
Technics SA-DX930 Sound cutting in and out
try rehooking up speaker wires. make sure no bare wire is showing and positive and negative are aligned correctly
May 19, 2009 | Technics SA-DX930 Receiver
Technics SA-DX930. I ran digital optical cable from the TV to the receiver using the tv/dss mode. It worked well for 4 months. It stopped working. I can get sound out of the receiver and speakers using...
If the only thing not working is the optical input, it is possible that the optical converter is defective. Without seeing the actual unit and testing the IC, I can't say for sure. If you have test equipment, let me know and we will attempt to track this down.
Dan
Mar 03, 2009 | Technics SA-DX930 Receiver
No remote control
found remote but its 50.00 at remotes.com
Sep 29, 2008 | Technics SA-DX930 Receiver
Remote control
I have heard the phillips makes one... Philips Pronto TS-1000
Dec 01, 2007 | Technics SA-DX930 Receiver
Technics SA-DX930 Receiver Logo
159 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
