Question about Veo Mini Capture Digital Camera
My digital key chain wont turn on if not plugged in to computer
How do I put pictures in the key chain slide show thing?
http://www.vistaquestusa.com/pages/service.htm
Click this link and find your camera to view the pdf manuals for your keychain (viewer) and camera. The pdf will explain how to connect your keychain to your computer to put pictures on it.
Good Luck! : D
May 26, 2009 | VistaQuest VQ-5115 Digital Camera
Digital Royal Key Chain - How do I download pictures?
Hi, the Digital Royal Key Chain has a mini USB port located somewhere, this should also be the port for the adapter to the built in lithium battery inside. There after, just plug in your computer and Plug and Play software should detect it. Then you can move your picture files, (.jpg, .mpeg, .gif, etc) and drag them in the drives folder. They should display then.
Mar 15, 2009 | Coby DP-768 7-Inch Widescreen Digital...
TRYING TO OPEN PHOTO VIEWER, WON'T OPEN
I have my key chain completly charged and the software downloaded and when I plug into the computer it says updating like ie is supposed to but then I can't into my pictures to download them onto the key chain
Dec 29, 2008 | Innovage Shift3 MP3 Player
Won't turn on
best advice is to try this on a windows computer it is possible there is a driver issue with that device on apple OS
Mar 23, 2017 | Electronics - Others
Photo key chain made by the sharper image and it wont turn on
Hold the play button for three seconds after you put it in the on position.
Dec 25, 2008 | Audio Players & Recorders
Coby Digital Photo Keychain DPKEY
Getting Started- VERSION DPKEY and 151SX
STEP-1
-INSTALL The Photo Viewer Software
Download & Install The Photo Viewer Software From Our Web Site:
The Driver CD files (Setup Guide, Manual and Photo Viewer Software) can be downloaded from
our web site. Click on the link below
http://www.cobyusa.com/?p=prod&prod_num_id=80&pcat_id=3001
NOTE:
Find your Photo Key Chain version and Download the Driver CD files along with all the latest
updates.
The version is listed on the back of the Photo Key Chain as 151SX, DPKEY or 151MP.
To Download & Install The Photo Viewer Software From Our
Web Site:
a) Create a folder
on your desktop before downloading the file from our website. To create
a folder on your desktop, go to your desktop and RIGHT click on your mouse. A set of
menus will appear. Select “New” and then “Folder” (you will notice a new folder will
appear on your desktop), give it a name, example DP151.
b) Click on the below link and select “Download”.
c) Click on your Photo Key Chain Version to start the Download. The version is listed on the
back of the Photo Key Chain (151SX, DPKEY or 151MP.
d)
After clicking on your version, you will prompt with a pop-up screen “Do you want to save
or open the file”. Select Save.
e) Another screen will prompt you to save the file on your computer. Save the file on your
“Desktop”, in the “DP151” folder and select “Save”.
f)
Once the download is completed, go to your desktop. Double-click on the DP151 folder.
g) To install the Photo Viewer software, Double-click on the Setup.exe file. Click NEXT on
all prompts.
h) After the installation. The Photo Viewer Software icon will appear on your desktop.
i) Done! ……Continue with “STEP- 2
STEP-2 CONNECT the Key Chain to your computer using the supplied USB cable. Upon
connecting the Key Chain to your computer, the Key Chain will prompt you to set the
device to “USB Charge or USB Update”. Select USB Update by pressing the Right
button and then the Middle button.
STEP-3 RUN the Photo Viewer Software to transfer photos to the Key Chain. Double-click on
the Photo Viewer icon located on your desktop. Once the Photo Viewer opens, it will
give you a message indicating “Upload Completed”. Click OK. (This message
indicated that the Photo Viewer Software has made connection with the Key Chain). If
you have received the “Upload Completed” Message, Skip STEP-4 and continue with
STEP-5
STEP-4 If you have NOT received the “Upload Completed” message, then you are
encountering the below error message:
Can’t Find any Photo Viewer, or
another program owns it. The
program will exit!
*Set the Photo Key Chain to USB update. SEE “STEP- 2”.
*Make sure the USB Cable is connected properly, you should hear a “clicking”
sound when the USB Cable is connected properly in the USB Port.
*The Key Chain should also appear under “MY COMPUTER” as a removable
disk. If not, switch the USB Port or replace the USB Cable.
STEP-5 LOCATE the images on your computer (See Diagram)
STEP-6 HIGHLIGHT the images files that will be transferred to the Key Chain (See
Diagram)
STEP-7 SEND the highlighted images to the Device Panel (See Diagram)
STEP-8 TRANSFER the images from the Collection panel to the Key Chain (See Diagram)
Disconnect the Key Chain from your computer. Done!
Nov 04, 2008 | Tao 1.5-inch Square Polished Silver Photo...
Coby 1.5" LCD digital photo key chain
uninstall photoviewer and put disc back in and install it again but don't run it . Plug in keychain-turn it on- click on arrow until it says update-use left or right arrow key and push middle button and it should start.
Sep 03, 2008 | Cameras
Photo digital key chain
If you have a INNOVAGE digital key chain and keep getting a error message when you click on the icon try right click on the icon then go to properties, left click on properities go to compatability and then click on windows 2000 for you with 2000 or XP. click on apply ok. This should solve your problem
Dec 27, 2007 | Baby Gear
Digital photo keychain
go to their website... www.mscustomercare.com and they have the drivers and stuff there....The problem i have is that after ive charged it for 3 days it wont turn on! It works when its plugged into the USB but as soon as i unplug it....wont turn on!
Dec 22, 2007 | Tao 89811-PB1 Digital Picture Keychain
Veo Mini Capture Digital Camera Logo
Top Veo Cameras Experts
Are you a Veo Camera Expert? Answer questions, earn points and help others
