Question about Vanguard 6430 Router
Need to reset Motorola Vanguard Router and what is the default ip
I bought a Motorola Vanguard Router 6430 and I need how to reset to factory default. I also need the default ip address to get inside of the router.
Need to access my Motorola router password...help! Bought a Kindle and cannot use it.
You might need to reset your router to the factory settings. First go to http://www.routerpasswords.com/ , select the manufacturer and make a note of the default usernames and passwords.
Then reset your router, by holding the reset button in the back for about 20 seconds.
This will reset it to default settings, and the password on the website above will work
Jun 13, 2011 | Arris Wireless G Broadband Router (wr850g)
I forgot my password and i cant let my friends use this line
If you forgot the password, resetting the router will allow you to access the router's configuration screen again. However, this will reset the settings to default, and you will have to reconfigure the router.
To reset the router to the factory defaults, press and hold the Reset button for more than five seconds. This clears the router's user settings, including User ID, Password, IP Address, and Subnet mask.
Here is the instruction manual for the WR850G Router (the above instructions are from page 1-8):
http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
Apr 11, 2011 | Arris WR850G Router (DHWR850G)
How to reset for factory default of vanguard 340 ?
Like most gadjets... look for a pinhole (either on the bottom or the back) labeled reset. Use a pen or paperclip to press the button while the unit is on. Hold and press for a few moments. You may also need to restart the unit.
Mar 12, 2011 | Arris Vanguard 340 Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
I forgot the password to my wireless connection and i need a passphrase or a key code to get online wireless. Please help, Evan
No choice, your have to reset the router to it factory default settings. Just look at the rear side of your router beside the power supply input, there is a reset button, just turn on your router and press the router for more than 5 sec. Please note that, this action will clears the router’s user
So please make sure u have that information before do so especially internet UserID and Password.
YBC (/\)
Oct 08, 2009 | Arris Wireless G Broadband Router (wr850g)
I need the line command set to configurate a Motorola Vanguard 6455, thank a lot...
Open command propmt, type there ipconfig and look for default gateway. Take note of the default gateway numbers and type that on the address bar of your IE browser. There you can setup the device.
Jun 09, 2009 | Arris Vanguard 6455 Router
Vanguard 6455: double configuration.
when u reboot your router, at POST type ZAP command.. by this you will reset your password as well as your configuration.
try this and let me know ... wht happen??????
Jan 28, 2009 | Arris Vanguard 6455 Router
Vanguard 6455 router lost password
in my experience, any router where you cannot access it, you will have to do a factory reset. Generally there is the small paperclip size button in the back that you press and hold for 10 seconds while the router is on. after that, you release and unplug the router. Press the small button, plug in the router, and hold it for about 20 seconds. Sadly, I have found this my most common and best answer...
Dec 19, 2008 | Arris Vanguard 6455 Router
Cannot access to router IP
This is presumably because you cannot remember the password. All routers have a reset button which will reset to the factory defaults. Should tell you how to do this in the manual.
Apr 12, 2008 | Arris SURFboard 2.4GHz Wireless Cable...
Open messenger ports
Here ya go: To use the configuration utility embedded within your Motorola WiFi Router, you need to connect to it using the HTTP protocol. Launch a web browser (Internet Explorer, Opera, Firefox, or Netscape, etc.) on your computer, type in http://192.168.10.1 (default IP address for its LAN/NIC Interface) in its URL/Location bar, and then press Enter on your keyboard. If presented with a user authentication (login) screen, try the following: Default Motorola Wireless Router Username: admin (lowercase) Default Motorola Wireless Router Password: motorola (lowercase) If you cannot login using the above, it may be so because (a) you are not typing your password correctly, (b) your CAPSLOCK key is on, (c) someone has changed password on your wireless router, and/or (d) the firmware (a set of instructions stored on an EEPROM microchip) encoded within your wireless router is corrupted. Consider resetting your router to its factory default settings if you are stuck.
May 14, 2006 | Arris WR850GP Router
Vanguard 6430 Router Logo
108 people viewed this question
Top Vanguard Computers & Internet Experts
David Payne
David Payne
Are you a Vanguard Computer and Internet Expert? Answer questions, earn points and help others
