Question about Norcent Technologies LT-2722 27 in. LCD Television
No power to tv
I turned on the tv yesterday only to get a single slight popping sound and then the power to the tv went off. I unplugged the unit for 30 minutes and then replugged it back in to no avail. Is there a fuse that could have shorted out and where would it be located to be replaced. Thank you
  • TEC-1 May 06, 2008
    I went to turn on the tv and nothing happend, I cheaked the fuse and it's ok, I tried another cord and nothing. Please help
    Mr. Rosado
    Problem Solver:
  • 14 Answers
Sometimes, during a thunderstorm a computer or television or gaming console can make a popping noise and be completely fried. And other times it can be protected through a surge protector and no lightning strike it and it still makes a popping noise. I have found out both the hard way. Every so often a television (like in your example) will fry its "motherboard" and the electrical components will be shot. Unfortunately, unless you can find a wiring manual, the best thing in most cases is to just replace the television. If you find a wiring manual check to see if a wire is melted inside the components deck on the back, but please please please and I can't stress it enough, 1) consult your owner's manual or warranty to make sure you're not violating it, thus making your TV a huge paperweight, and 2) be EXTREMELY careful. Wiring is not something any person should attempt without basic knowledge of electronics. I would recommend an electrician friend or someone who knows wiring to look at it, that is if you don't.
Posted on May 01, 2007
Projection T.V. will not operate?
it sounds like it is a mechanical problem (i think the ray tube broke)
it looks like the tv needs to be professionally repaired or replaced
Dec 17, 2007 | Televison & Video
My tv is 3 years old. I was watching it yesterday.Something poped and it went black. what is wropng?
A capacitor shorted (popped) in the power supply then the fuse blew (went black) unplug TV, remove back cover, look for power supply; follow cord to it; find small silver can with top bubbled (bad)
unsolder/replace; replace fuse. plug in turn on.
Mar 20, 2010 | Protron PLTV-32 Television
My tv made a popping sound, the screen went blank
Any set is repairable. It is the question of the cost and the availability of replacement parts.
It sounds like a component overheated and blew. Most likely there will be collateral damage where other components will also be damaged.
The failure could be in the power supply, or in any of the main drive circuits in the set.
You will have to call for a service estimate. In considering the age of this set, my preference would be to go out and get a descent LCD or Plasma set. The picture quality and performance of these new sets are far superior to the one you have!
Jerry G.
Nov 14, 2009 | RCA D52W23 52" HDTV CRT TV
TV made a loud crack or pop and the screen went black
Well if it is DLP TV then crack/ pop sound was broken lamp in TV and if its another kind of TV as you did not mention its model and brand then have to check accordingly.
Nov 10, 2009 | Audio Players & Recorders
I have a Toshiba TV model 36A43 that won't power on. The same thing happened yeaterday as this morning. The tv will not power on via remote, or the manual power button. Yesterday, the same thing occurred...
It sounds like you have a switch problem at the front panel of the set. If a switch gets stuck internally the micro is trying to process the command and won't respond to any other commands. The only way to find out is to go into the set and desolder all the manual switches and see if the remote will work the set. It has a seperate detector for the remote. Thanks for using fixya. Good luck
Nov 08, 2009 | Toshiba 36A43 36" TV
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Oct 22, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Tv plays sound but no picture or any signs of backlight
This sound is a capcitor pop and this could be in the power supply unit itself. The glass could be a fuse that took the brunt from the capcitor pop.
1. Unplug the unit and do not plug it in.
2. if its under warrenty take it in please!
3. if its not under warrenty and you know eletronics verify what cap popped and replace that and the fuse.
4. if you do not know about eletronics this work would cost you around $150 for the wrok done.
Good luck I hope this information helps you!!
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Norcent Technologies LT-2722 27 in. LCD Television Logo
111 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
