Question about Pioneer PDP-6010FD 60 in. Plasma HDTV
Tv won't turn on
I have a pdp-6010fd and it won't turn on the standby light is on so the mAin switch is on but i can't get it to power up.
  • ryschumacher Dec 30, 2008
    had to get into service menu and reset
    went ito service menu and reset tv
5 Suggested Answers
SOURCE: pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
  • 41 Answers
SOURCE: tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Posted on Mar 30, 2009
  • 41 Answers
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
SOURCE: my brandnew Pioneer PDP-5020FD won't turn on.
Check page 9 of this document:
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/PDP-5020FD_OperatingInstructions0610.pdf
You will see that there is a power button on the bottom right corner of the back of the unit (item 25). Turn the unit on using that first.
Posted on Aug 10, 2009
SOURCE: My Pioneer PDP-507CMX won't turn on. Standby light
wot is buttons&ir lock
Posted on Sep 05, 2009
Does not turn on. Prior worked but shut off after about 30 min/blue on light flashed. Replaced Y board and now does not turn on but blue light on . Put the old Y board back, still does not turn on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jan 27, 2016 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Tv just makes a click noise when pluged in
remove the back and look for any swollen or blown capacitors. it sounds like your power board went out
Dec 02, 2013 | Pioneer PDP-6010FD 60 in. Plasma HDTV
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Problem with Pioneer PDP-6010FD
Hello
The set can be set right by repair. You must have through knoledge in electronics to do work with set. especially, plasma displays will have very complicated circuits. It Sustain-Boards suld be trouble shooted.
Feb 21, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
I can't get it to power on.
You press menu or you can take the plug out the wall and plug it back in
Apr 21, 2009 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Tv stuck on standby
Jan 08, 2009 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
Pioneer PDP-6010FD 60 in. Plasma HDTV Logo
63 people viewed this question
Top Pioneer Televison & Video Experts
Electro Med Services...
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
