Question about InFocus ScreenPlay 4805 Multimedia Projector
Projector when turned on has no colour
The screen is black & white, have tried the colour settings but still no joy, can you help me.
  • 167 Answers
Hit the side of it or jiggle the inputs where the cable is. A projector at computer camp had this exact same problem but have this projector looked at by a professional. you might need a new colour wheel. i might be wrong but there isn't too much i can do
Posted on Jan 26, 2008
SOURCE:
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Office Equipment & Supplies
Too Much Green
Please check out this link for manufacturer information:
http://www.infocus.com/support/Products/Projectors/LP240.aspx
Jan 10, 2008 | Televison & Video
I want to connect my Sony projector to a Humax freesat box - I am only getting a black & white picture - how do I get a colour picture
may be the Sony Projector performs the black and white functions only,So kindly get a coloured projector
Jun 20, 2010 | Sony VPL-CX75 Multimedia Projector
I have a TRV-35G and the colour is predominately green which I cannot correct across the whole screen with the joystick control. Where the colours of the picture have been corrected (across 2/3 of the...
Try turning colour correction OFF. (button in up position). See what affect the iris control has. This control will changed the color of the slide from deep red at nearly closed to washed-out blue and white. at full open. I adjust the controls for each slide. The color temperature of the 8549 lamp varies with the brightness. lower level warmer, higher cooler.
Dec 02, 2009 | Elmo Projectors TRV-35H Slide Projector
White screen on my camera and can take picture picture is black colour
hi
i think the LCD has been set to a very high brightness set the LCD brihtnes lower from the settings..
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and other settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
May 17, 2009 | Samsung Digimax L60 Digital Camera
Connection Identification, experiencing no Sound
Thank you for your help I visited a Sony retail outlet yesterday and they explained that to obtain sound you have to go through a sound system using the red connection because they is no sound / speakers build into the projector.
Feb 13, 2009 | Sony VPL VW10HT Multimedia Projector
My projector only shows black and white images
probably you are facing with an NTSC signal and a PAL source or vica versa
try to check with a regular tv or with a different source
Jan 03, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Sony VPL - ES2 Colour problem
Isolate problem by using video and data(PC),if none of the imputs work call the vendor or Sony and sent it back for repair.
Aug 31, 2006 | Sony VPL-ES2 Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
115 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
Marvin
Marvin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
