Question about BypassKit - NISSDL - Nissan And Door Lock Alarm Interface Bypass M
Alarm wont stop
Car wont start. the lights and horn are blinking and beeping
  • 34 Answers
Press the lock/unlock button on the remote and sometimes the brake pedal as well then it should work.
Posted on Jan 09, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Hazard lights flashing and alarm sounding. How do I stop these?
Every car brand and model has its procedure to stop the flashing light and alarm sounding.
But still the common procedure is Make sure boot and bonnet are closed properly.
It can also be a switch, but check your alarm by locking yourself inside the car, and then press the close button on the key 2 times repeatedly until the lock control on the door doesn't make anything. Then open the door by pushing the lever or open the hood . If the horn sounds and the lights blink your alarm is ok , if only the lights blink you should take it to dealer. You can stop the hazard lights and horn sound by pressing the unlock button on the key.
May 12, 2016 | Cars & Trucks
I have a 2009 elantra and when doors r locked and I hit the starter the car lights blink twice and doesn't start! It was a factory install by Hyundai . The car is an automatic . What do I do? Thanks
I would return it to the installer
My 2012 Hyundai Elantra Wont Start - CarGurus
www.cargurus.com > Questions > Hyundai > Elantra
CarGurusJul 30, 2013 - My 2012 hyundai Elantra GLS would not start this morning. ... I hit my door unlock on mt Key fab and the doors unlocked fromt here I proceeded start my car.... it and it wont turn over just makes a light click. not like a battery issue. .... But if Istart from the zero position on the starter it doesn't start on the first try ...
No horn / No lights when I lock my car - Hyundai Genesis ...
www.gencoupe.com/.../244433-no-horn-no-lights-when-i-lock-my-car.h...
Mar 30, 2014 - 16 posts - ‎8 authors
I do not know what could have caused this but when i lock my car... ... lock yourdoors with your key fob(might have to hit the lock button twice) ... The alarm/horn should start beeping. ... 2010 Hyundai Genesis Coupe 2.0T R-spec in Karussel White.... My lights flash when I lock it, but the horn doesn't sound.
2013 Hyundai Elantra Engine Won't Turnover, Won't Start ...
www.carcomplaints.com/.../Elantra/.../engine_wont_turnover_wont_start...
The 2013 Hyundai Elantra has 19 complaints for engine won't turnover, won't ...
Jan 04, 2016 | Hyundai Cars & Trucks
I disconnected the battery when I reconnected the battery the alarm keeps going off
If a aftermarket alarm then disconnect it ,these auto remote start alarm things are useless and all go wrong with age
Oct 20, 2012 | 2005 Dodge Caravan
94 camry alarm would'nt stop i pulled a black wir next to the horn now car wont start
the wire from the horn is part of an imobiliser so it wont start replace wire it sounds like imobiliser battery or alarm pad if wont turn off
Oct 13, 2012 | Toyota Camry Cars & Trucks
The horn on my car (which is my car alarm) goes off on its own
There are relays in the cars security systym that may be sticking, they use elec. relays for everthing in there and they start going bad and it wont start, maybe you can run a new wire to the horn to bypass the computer.
Aug 16, 2009 | 1996 Chrysler Cirrus
Horn beeps as if in an alarm mode
My 4Runner did the same thing. What I did was just put a new battery in hook it up and let it honk. Put the key in the ignition and start it and it should stop. It is in alarm mode.
Jun 25, 2009 | 1996 Volkswagen Jetta
When i start my 2006 chrysler 300c the horn will sound and will not stop till i turn the car off
Sounds like you have a problem with the alarm system. Does it beep, or blow at a steady keel? If it beeps, alarm, if it blows steady, look for a stuck horn pad.
Jun 09, 2009 | 2006 Chrysler 300
2000 Honda Accord Alarm does not arm
Blown fuse?, check to owners manual for a theft system fuse.
Feb 27, 2009 | 1998 Honda Accord
Car alarm stopped working.. Car wont start
the jetta has a faulty alarm system from the factory i have been working on one in my shop. the alarm moddule is inside the dash behind the light switch and has a 10 pin connector and a 6 pin connector. this can be bypassed if you disconnect both connectors and jump the two large wire on the 6 pin connectors, these wires operate your starter. the car will start and run but your alarm will no longer be active. the door locks and everthing else will still work. the only issue i am having is the factory radio isn't working because it is controlled by the alarm. but worse case scenario i can use an aftermarket radio if need be.
Feb 20, 2009 | 1994 Volkswagen Jetta
BypassKit - NISSDL - Nissan And  Door Lock Alarm Interface Bypass M Logo
480 people viewed this question
Top Infiniti Vehicle Parts & Accessories Experts
advance tire and...
Level 1 Expert
Bill Boyd
Tom Chichester
Are you an Infiniti Vehicle Part and Accessory Expert? Answer questions, earn points and help others
