Question about Sony Handycam DCR-HC46 Mini DV Digital Camcorder
Reinsert cassette error... cannot record via tape
Each time I insert a Mini DV cassette, I get a pinging warning and a error message to reinsert cassette. The manual tells me to use a new new cassette which I did...same error. I have reset the camera no improvement. This happens on both battery and AC. I have also left the compartent door open overnight to dry out any possible moisture. What is even more weird is that I have a Sony HI 8 Handycam and it recently started giving the same error message. The Mini DV has only been used for a few hours total. Thanks
  • Anonymous Apr 05, 2009
    Tape will not insert
  • 76 Answers
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
Posted on May 15, 2007
When i insert the Sony Cassette i get the message Reinsert the cassette what can i do
there is a caasette called cleaning casette in the the shop itself
oyu can get it from the shop itself
its the same as the cassette
Dec 13, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
"Remove the cassette"
I only got the problem when the tape was bad. Usually the ribbon got folded, or was very wrinkly looking. Eventually I found out the drive was bad, and had to have it replaced.
May 08, 2010 | Canon XL1S Mini DV Digital Camcorder
Reinsert cassette - After inserting a cassette the on screen message reads as follows "reinsert cassette" a further message C:31:23
when ever to get this kind of message just try to fwd the tape mannualy, or just make sure tht when u are rew. the tape dont rewind tht completely....
Jan 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
When I insert the cassette into the camera it won't close.
Try the following link to troubleshoot this issue:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
Aug 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Mar 07, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
Re-insert cassette
the flexwire of the camera at the bottom of the mechanical assembly is already cut..it is need to repair that flexwire or replace the mechanical assembly to sony service center...
Dec 31, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Remove tape error message
  1. Condensation is detected – If condensation is detected by the camcorder, the “Remove the Cassette” warning may occur.
  2. Component failure – If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder.
  3. Sand or grit damage – The camcorder’s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate.
  4. Impact damage – If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur.
  5. Liquid damage – If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation.
  6. Improper videotape insertion – If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual.
  7. Damaged or defective tape – If a tape becomes damaged, please discontinue its use.
Operational Recovery Steps
Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps:
  1. Eject the videotape
    Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2.
  2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry.
Nov 19, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Open Questions:
Sony Handycam DCR-HC46 Mini DV Digital Camcorder Logo
775 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
