Question about Sony PlayStation 2 (PS2) Console
Ps2 browser/system configuration menu will not display
My girlfriend was navagating through the system configuration menu and accidentally changed one of the settings and then hit x instead of 0 and now the browser/system configuration will not display-screen just remains black. I have never had any problems with my PS2 and all of the hookups are correct.
  • Devilman501 Apr 24, 2009
    My console starts up. Green and blue lights are on, everything is plugged in, and all cords work. Does not display anything on television, nor does play any sound.
    All cords are secured in there, and it's on the correct channel. Playstation makes buzzing noises like normally, and even seems to read the disk. Just no display/sound on television.
Cerfer39
  • 709 Answers
SOURCE: PS2 Wont Play
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Posted on Nov 07, 2007
  • 6 Answers
SOURCE: disc not spinning browser/configuraion display on screen.
  1. Check to see if a Music cd will spin in the console
  2. Open flip lid and examine the reset switch - check to ensure the switch is intact - you are looking for a small lever which is made of lack plastic. If its not there you need a new reset switch
  3. If the laser is not moving at all you will need to open up the console (WILL OBVIOUSLY VOID YOU WARRANTY!)
  4. Check the PCB switch at the rear of the console. This part connects to the lid of the ps2 if thats is broken you will need to replace - difficult to source but they are available
  5. Check the ribbon cable underneath the PS2 Laser for any signs of damages
  6. Check the ribbon cables x 2 which attach the laser assembly to the motherboard
  7. Remove the motherboard metal shield and test the SMD (SURFACE MOUNTED) on the underside of the board use a multimeter for this
  8. If your console passes all these tests the most likely cause is a blown laser which is a simple part to source via ebay etc.
  9. If your new laser does not fix your problem then you have a blown RS2004 chip which is expensive to replace and usually not economical to do.
Posted on Dec 08, 2007
  • 5 Answers
SOURCE: not recognizing disk
My PS2 always does that now. Just make sure it's reading the disc in the System Browser, and it'll play fine.
Posted on Jun 28, 2009
  • 12 Answers
SOURCE: Browser and system configuration only appear when ps2 turned on
try cleaning laser with rubbing alcohol and a q tip
Posted on Jul 06, 2009
SOURCE: ps2 system configuration
Hi mate i hav a good link for u ,usually the issue is your ps2 disc cover not activating the microswitch fully.what u have to do is to see this link and study how to do it or get friends and family to help.http://search.speedbit.com/searchresults.asp?q=you+tube&client=pub-1734327923886716&forid=1&channel=9518150362&ie=UTF-8&oe=UTF-8&cof=GALT%3A%23008000%3BGL%3A1%3BDIV%3A%23336699%3BVLC%3A663399%3BAH%3Acenter%3BBGC%3AFFFFFF%3BLBGC%3A336699%3BALC%3A0000FF%3BLC%3A0000FF%3BT%3A000000%3BGFNT%3A0000FF%3BGIMP%3A0000FF%3BFORID%3A11&hl=en
Kindly RATE ME!!!!!!Thanks ,Good Luck Mate.
Posted on Sep 27, 2009
My counsels time resets to 1/1/2000 why?
That is the default setting when you reset the PS2, It's programed into the system. Since PS2 came out in May 2000 it automatically sets the time to the beginning of that year which is 1/1/2000
If you want to change it you
1. If there is a game disc in the console, remove it and then power the unit on/off.
2. When the opening screen appears, choose the bottom option of the two. One will be time and date
6. Return to the Time and Date Setup and verify or set your time zone.
7. Press CIRCLE to exit the configuration menu.
8. Insert the game disc and navigate to the Browser menu to select the game or browse the memory card.
May 29, 2011 | Sony PlayStation 2 (PS2) Console
During setup selected wrong language - how do I change to english
Start up your PS2 (without a game or movie), you will see "browser" and "system configuration". Go to system configuration(Configuracion de Sistema) something like that, and scroll down until you find language(Idioma). press X and you can choose from about 8 languages.
Dec 25, 2009 | Sony PlayStation 2 (PS2) Console
My playstation 2 plays dvds in spanish how do i change it back to english. Is there an easy way to do this
once you start up your PS2, you will see "browser" and "system configuration". Go to system configuration, and scroll down until you find Language press X and you can choose English
Dec 07, 2009 | KEIO PS2 Optical Scroll Mouse
Playstation 2
it is where you set-up your internet connection and modify the way it displays. if you don't plan to play you PS2 online then i wouldn't worry about it.
May 31, 2009 | Sony PlayStation 2 (PS2) Console
What's up with Guitar Hero World Tour disc not loading on the older PS2?
I think maybe that the guitar hero world tour is to new for the old ps2. I think that it only works on new ps2's.
Dec 24, 2008 | Sony PlayStation 2 (PS2) Console
My 8 yr old accidentally changed the language from english to spanish, how do i get it back to english?
Start up your PS2(without a game or movie), you will see "browser" and "system configuration". Go to system configuration(Configuracion de Sistema) something like that, and scroll down until you find language(Idioma). press X and you can choose from about 8 languages.
Dec 22, 2008 | Sony PlayStation 2 (PS2) Console
Turn on PS2 console...Browser and System Configuration
some do tjis it s a system defalut if it has trouble loading the disc dont worry though as long as it loads the games
Dec 15, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Browser shows no data on PlayStation 2 Console
I am having the same problem with my PS2, but I have an HDD inside of mine. I am told this is a circuit problem inside the PS2 that doesn't allow the information to be transfered to the RAM. That's why you see “No Data” instead of the usual problem of “Disc Read Error”. I hate to say it, but it sounds like you are going to have to do the same thing I am about to do. Send it in to Sony and get it repaired.
I am also pretty sure this PS2 you are talking about is the large fat one, and not the slim one.
Sep 03, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 screen display problem
Try reset to the Default Configuration, Remove the Memory Card and try this:
Press the Power and turn off,
Press the Power and Turn on, without a MC the default has been charge.
- No have a "reset sequence" but I can send to you a sequence to reset rgb without video".
Sequence: when the ps2 sound "ready" press:Down, X, Down, Down, Down, X, Right, X.
After Default Load, in "Browser" put your memory card and delete a System Configuation for the MC, the icon is a PS2, and save a new configuration, Done, if the problem not solve, send me a mail or msn gamba.support@hotmail.com (Mail and MSN)
Dec 17, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
998 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
