Question about Nikon Coolpix 3200 Digital Camera
I received cyberpix S-5115 - and having alot of problems - battery card and loading problems - camera off and on etc
I have a cyberpix s-830d and aftera couple of pics batteries are drained
Hi kane_ell,
Depends on the battery's usage , if you have been using the batteries for quite , long then most probably it's the time for replacement.
However if the batteries are new then the problem is with the firmware which needs to repaired by the service center , so you can check if the camera is under warranty and do it for free , else inquire about the repair charge and check if that is OK with you.
Hope that helps ..:)
Sep 09, 2011 | Mercury Electronics CyberPix S-555V...
My camera the mercury cyberpix 2-210s only take 20 or so pictures and has a memory card of 8 mb and I don;t understand why.
Your Mercury Cyberpix S-210S has an internal memory of 16MB and can be expanded using an SD/MMC Card up to 512MB.Since the picture you capture using this 2 Megapixel camera has an approximate resolution of 1600*1200 and a size of approximately 400kB you can store only around 18 to 20 photos in an 8MB Memory Card.So if you want to store more pictures you have to insert a Memory Card of bigger capacity.Remember the maximum Memory Card capacity supported on your camera is 512MB.Thanks for choosing Fixya.
Jun 19, 2011 | Kobian Mercury 3.1 Deluxe Classic Digital...
Camera seems to be locked...
It's not a key pretty sure it's your flash isn't turned on to do so. hold the flash button it will blink a red light and it should go away!
Dec 27, 2008 | Kobian CyberPix E-550V Digital Camera
Cyberpix s-555v
sounds like a problem with the usb cord and you need to write the company and they are really good about sending out another one,same thing happened to me too.
Sep 12, 2008 | Mercury Electronics CyberPix S-550V...
Mercury cyberpix e-5205
These cameras are power eaters. I had the same problem. I also noticed that inside the battery area that there was some corrosion on one of the posts. I cleaned it off and it works better. The battery's are low if it shuts off like that. You are best to use rechargeable batteries and take them out when you are not using the camera. Do you have a manual? If so contact me at hansonkster@gmail.com.
Feb 14, 2008 | Mercury Electronics CyberPix S-550V...
Connecting to my laptop copyuter
Try here. www.camerahacker.com/Forums/DisplayComments.php?file=Digital%20Camera/Others/Mercury_CyberPix_S-550V_Manual
Or www.mydownloads.com. you can use any shoot&store scan disk card under 1 gig. thesage
Jan 27, 2008 | Mercury Electronics CyberPix S-550V...
Istall camera driver of CyberPix S-550V Digital Camera
Hi , i have donot have a driver software CD. I need to install and using it as a webcam. THANKS ALOT . I AM FROM TABRIZ,IRAN
Jun 02, 2007 | Mercury Electronics CyberPix S-550V...
Nikon Coolpix 3200 Digital Camera Logo
59 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
