Question about Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 bootup disk
I get a blue screen when starting up gateway loaded with windows xp media center edition. I cannot even start it up in safemode it crashes and freezes. I want to try to save data from the hard drive. I do not want to use the recovery cd since it will wipe all data out. Is there anyway I can make a bootup disk from the revovery disk or does anyone know where I can obtain one.
  • annafh Jan 01, 2009
    Thanks, I did what you said but I am having problems with the knoppix cd. it will start up then give me an error. it says kernel panic - not syncing: vfs : unable to mount root fs on unknown - block (1,3). I tried burning a another cd. I get the same error. I would originally take the hard drive out and put it in another computer as a slave but the compuer is still under warranty, warranty does not cover virus. Do you you have any other suggestions, thanx
  • 585 Answers
If you have good internet access, you can download a live Linux distribution such as Knoppix, and burn the it to CD. Don't let the word "Linux" scare you out of this, Knoppix is very user-friendly. And there is loads of resources available online. Anyway, burn the CD, and boot the computer from it. It will take a little time to boot, as it is a live version running only in RAM. It has very powerful applications though, and you can access your hard drive from it so long as the drive is not corrupted beyond readability. If you can access the hard drive, you can view your files, and copy the files to a USB drive. Once you have your data, you can then shut down and restore windows if the drive will cooperate, or install to a new drive if necessary.
!!! Knoppix will not write to or erase any data from your hard drive without you give it permission to do so !!! It is about your safest option in that respect.
Just google Knoppix to find download sites. Most sites have instructions for downloading and burning your copy. And it's all FREE!!!
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 30, 2008
  • Bruce Volkers
    Bruce Volkers Dec 30, 2008
    I see others have problems with this Gateway model. If you are unable to get Knoppix to boot, your hard drive and windows system may actually be intact, and you instead have a hardware problem with your Gateway. In which case, you may be better off putting your hard drive in another computer as a slave and reading your files that way. Good Luck!
I got a nasty virus that disabled my ability to start up my windows xp. no matter what I do it takes me back to the screen where you can choose to run it in safe mode.Every choice that I have tried it...
have you tried the guide to trouble shoot the problem http://www.helpowl.com/manuals/Gateway/GT4010/83386
as you said that you are not able to start the computer it can only be solved by using a BOOT CD of a data recovery software, as this CD will help you boot your system and recover the lost data, It will also help you to recover the product key of the older version of the XP version installed
Dec 16, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
I have a gateway gt4010 with some virus, i reinstalled recovery CD, but it showed "window root" error message w.hal.dll missing... can you to give some tips on this?
Most Gateway systems can be restored to factory settings using the following steps:
Turn on the system and repeatedly tap F11 key (before windows starts to load)
In the System Restore Options dialog box, click Full System Restore (with Backup), and then click Next.
Wait for the recovery process to complete.
Thanks
Mar 07, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Having a problem with my gateway comp. using
  1. Boot to your XP CD, enter Recovery Console and run the command CHKDSK /R and see if that resolves
  2. Run diagnostics on the HDD, it may be failing, replace HDD if diags fail
  3. In-Place (Repair) reinstall of WIndows http://windows.microsoft.com/en-us/windows/help/install-reinstall-uninstall
Jan 25, 2010 | Microsoft Windows XP Media Center Edition...
My 2004 Gateway model 5200x has the version of Windows XP that came withit when I bought it from Gateway. About a year ago I could no longer change anything but the color on the desktop. When you first...
If it has an onboard video card then reload the video driver.
If it has a PCI-e / AGP video card then download latest drivers and re-install driver, Dont forget to un-install original driver first.
Failing all that see if you can edit the screen resolution in safe mode. (Press F8 when you first switch PC on.
Jan 03, 2010 | Microsoft Windows XP Media Center Edition...
Dont have recovery disks and have virus...actually just missing disk 2
If the popup you're getting is from something like "MS Antispyware 2009" or similar, that's the same trouble I've seen on several other computers. Download a removal tool called ComboFix. You can find information on how to use it and links to download it here. This is a handy tool even if the virus you have is different as it will fix a number of virus and trojan problems. ComboFix can be run in safe mode if your computer can't start all the way into Windows. Turn your computer on, and when you see the Gateway logo screen press the F8 key. This will give you a startup menu screen from which you can pick starting in safe mode. This prevents Windows from loading everything except the minimum stuff it needs to start. Run ComboFix and let it repair the troubles it finds.
May 25, 2009 | Gateway 835GM (835GH) PC Desktop
I need to reinstall XP media center on my Gateway PC
If you know somebody that has the same operating system disc (Windows XP Media Center Edition) you can use their CD to reinstall Windows and just use your product code number on your PC box.
Mar 15, 2009 | Computers & Internet
How to get Recovery Discs for refurbished Gateway MT3705
If the computer has the same version of xp on it that the disk has,Just restart in safe mode,Select safe mode with command prompt,When it get to the command prompt,Put the xp disk in and type
SFC /scannow
This command will immediately initiate the Windows File Protection service to scan all protected files and verify their integrity, replacing any files with which it finds a problem.
Windows XP keeps a cache (copy) of these essential files at the following location:
C:WINDOWS\System32\Dllcache
But it still may ask for the disk.
Please rate this a fixya
Feb 14, 2009 | Gateway MT3705 Notebook
Windows xp wont allow to login
Very possible depending on the computer as you boot up you will see a message to depress F2 or F8 or F10 or possible the del key to start a system restore. Tap on of these keys as it boots up and you should go into the restore mode....
Aug 01, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway stays 10 min at BIOS splash screen
I would say there a minor corruption in your hard drive. How old is this computer?? May time to reformat it.
May 15, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 (RBGT4010) PC Desktop Logo
320 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
