When I boot up my toshiba laptop, the toshiba screen comes up normally, but the Windows screen never loads, but the screen is completely dark and blank. the menu of f-2 and f-12 also show clearly when they are accessed at power-up
    New Friend:
  • 21 Answers
Hello, you will have to reload the operating system. The window operating system you are using is corrupt. Therefore, install a newer and original version of it. If it works, please rate my solution on fixya. Thanks.
Posted on Dec 30, 2008
I have a toshiba L305-s5984 and it will not boot until i press the page-up or page-down key then it will give me a video screen. the machine apears to have power but nothing on screen. only a black...
not sure if this will help you ...
How to Restore a Toshiba L305The Toshiba Satellite L305 notebook computer has a recovery program pre-installed at the factory that lets users return the hard drive to its out-of-box state. Using the recovery feature completely deletes all software and options saved on the laptop, which resolves any boot up problems and removes any virus infections. The recovery option isn't accessible directly through the operating system however, and must be accessed by starting up the computer in a different way than normal. Step 1 Close out any software currently running on your Toshiba Satellite L305 laptop. Navigate to the laptop's "Start" menu and choose "Shut Down."
Step 2 Hold down the laptop's "0" key and press the power button. Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen.
Step 3 Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option.
Step 4 Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again. Wait for the "Press any key" prompt to appear and tap a key to restart the laptop.
Step 5 Use the prompts that appear on the screen to choose your region, time zone and keyboard settings. Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system....
if this is no help to you then go to this link...
how to boot up toshiba L305 s5984 Google Search
Oct 24, 2017 | Computers & Internet
My laptop has been freezing for a while now, I've been getting a black screen with a blue bar across the bottom of the screen where the taskbar should be. Sometimes it boots up and makes me go into...
If you have Windows Installation disk, use to repair Windows.
First go inside BIOS(Setup) with Del or F2 and change under boot options for CD/DVD to boot up first before HDD.
Put the CD in, boot from it and select repair windows once it comes up
Jul 19, 2010 | Toshiba Computers & Internet
Laptop wont even attempt to load windows??
With this kind of problem, you must put in the Windows software disk and boot. Then select repair Windows from the list. This option will attempt to correct the problem.
If you do not have the disc, boot into the repair / diagnostic mode from the boot screen. See if there is an option to create boot disks.
Jan 04, 2010 | Toshiba Satellite A70 Notebook
Screen "Flashes" on/off
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 12, 2009 | Toshiba Satellite A135-S2276 Notebook
My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
May 08, 2009 | Toshiba Satellite Pro L300 Notebook
Need help with toshiba dynabook satellite 1801
Sounds like you may need to re/install or update some drivers.
Attempt to boot the machine into Safe-Mode.
Continuously hitting F8 while booting will get you to the Boot Option Menu.
If you can successfully boot into Safe mode, this may be enough to put things back together.
Attempt Safe-Mode and if successful try a normal boot.
Start from there and let us know the results.
Apr 14, 2009 | Toshiba Satellite A135-S2276 Notebook
Vertical Lines Display - Recovery shows setup not complete
As per my experience, the problem is not because of your Video Card/Driver. Such a problem arises due to faulty RAM. Change your RAM and enjoy computing.
Thanks
Sep 13, 2008 | Toshiba Computers & Internet
Screen goes blank(not Black, but dark) after windows boots
Perhaps it is trying to power an external monitor. Try this: Once your computer boots up, hold down the "fn" key (usually bottom row of keyboard) and then hit the key that shows what looks to be a monitor on it. Usually on the Toshibas, its the F5 key. This key will always be in the F key row. Let me know if this helps.
May 14, 2008 | Toshiba Qosmio G15 Notebook
Laptop screen does not show desktop and remains blank after boot.
This is a driver loading problem, where the OS is trying to load a communication layer for a device which then fails and drives the machine into a steady loop. Unplug all devices and cards from the machine and reboot. If this works normally, you have a device driver problem with one of the things you have plugged in and need to troubleshoot it from there. If it still hangs, I bet you have a bad video driver (or USB driver). Reboot to SAFE MODE and then try changing the drivers for video and USB (and then motherboard drivers if any) to Microsoft standard distribution drivers until you get a normal boot and know which device/driver set are causing the trouble. Then hunt up updated drivers for that device on the web. Vista especially is very driver buggy.
If all else fails, reinstall the operating system using the REPAIR option.
Good luck...
Nov 16, 2007 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
David Payne
David Payne
