Question about Sony PS-LX300USB Turntable
Can't get sound from turntable to pc speakers
Sony turntable usb - setup but no sound. what do the setting need to be to monitor while recording?
  • 10 more comments
  • lneathawk Jan 02, 2009
    When I plug the turntable usb into my computer not only do I not get sound from the turntable I loose all sound from other software (iTunes).
  • Anonymous Jan 09, 2009
    I have the same problem and I was told it was "normal"!!!
  • driordan Jan 10, 2009
    Just bought the same Sony turntable. It will record but I get no sound.
  • jama37 Jan 17, 2009
    I thought I was alone.
    I'm running Vista Home Premium with an Athlon 64x2 processor.
    I can record but I can't monitor the sound while recording.
    Also, unless I un-plug the USB cable my speakers won't work for any other sound application.
  • dougwalk271 Feb 09, 2009
    Exact same problem as the rest of the posts. Using a Sony PS-LX300USB with Windows XP Home SP2 I get no sound at all - I can't play direct and can't listen to anything while recording. No sound from any other applications (i Tunes, Windows Media, web sites) while the turntable is plugged in. As soon as I unplug the USB cable from the turntable the rest of the system returns to normal. Checked out the Sony site but it was no help;
  • angel rose Feb 11, 2009
    I have the same problem I am hoping there is someone out there that can help me. I can't believe it costs $15.00 for phone line tec support.
  • Anonymous Mar 03, 2009
    no sound!
  • Jennifer Stotler
    Jennifer Stotler Mar 03, 2009
    Same here. Have the Sony PS-LX300USB. Using on HP with Windows Vista. No sound while playing or recording. Hooked up with USB cable.
  • Jennifer Stotler
    Same problem. Sony PS-LX300USB turntable hooked up with USB cord to HP with Windows Vista. No sound while playing or recording.
  • Anonymous Mar 17, 2009
    I have the same problem it sucks.that's why I got it.
  • novichok Apr 12, 2009
    Great for recording --Just can't monitor- Major Bummer
  • Anonymous Mar 18, 2014
    Sony sp-lx100
  • 3 Answers
Go to control panel, sound audio devices, hardware , USB Audio Device Properies, Properties, click the + next to Audio Devices USB Audio Device Properties, make sure that is highlighted, click do not map through this device, apply restart program. Under device properties make sure sound playback is set to default driver ie: Realteck Ac97 audio etc... Hope this helps
Posted on Sep 23, 2009
  • 3 Answers
For those of you using the LX300USB ... to have "other sounds" go to control pannel / audio settings and chose your regular sound card as the default device for playback ... But I'm still stuck with the record monitoring ... but it works on my other laptop ... strange isn't it ? Hope this could help Emurga
Posted on Jun 09, 2009
Bad sound quality
You cannot connect the turntable via a microphone port. You need to connect via a USB port. If you have not got a USB port to connect it as the others are in use, you can buy an extension USB socket which, will allow you to put more devices via one USB port.
Sep 04, 2013 | ION Audio Vinyl Recording Turntable
Appears to be installed properly but doesn't record
When you first connect the turntable, Windows XP (and Mac OSX) will often select the "USB Audio Codec" as the audio input and output for your entire system. Since your turntable does not have speakers, audio will not be heard from your programs until you tell Windows not to use the turntable as an output device. Here's how to change these settings so that your internal sound card will always be used for playback whether or not your ION TTUSB is connected via USB:
    For Windows:
  1. On the bottom left of your screen, select the "Start" menu.
  2. Select "Settings" then "Control Panel".
  3. In the window that opens, select the "Sounds and Audio Devices" icon. (If you don't see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the "Sounds and Audio Devices" icon should become available in the list on the left.
  4. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window.
  5. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or "Microsoft Sound Mapper".
  6. Under "Sound Recording," select "USB Audio Codec" for your default device.
  7. Check the box titled "Use only default devices".
  8. Click "Apply"...then "OK".
    For Mac:
  1. Open your Hard Disk.
  2. Open your "Applications" folder.
  3. In the "Applications" folder, open the "Utilities" folder.
  4. In the "Utilities" folder, open the "Audio MIDI Setup".
  5. In the "Audio MIDI Setup" under Audio Devices, set:
    • "Default Input" to "USB Audio Codec"
    • "Default Output" to "Built In Audio"
    • "System Output" to "Built in Audio"
Now, all programs, including Audacity, will only use your internal sound card for audio output.
Dec 26, 2007 | ION Audio iTTUSB Turntable
No sound with Sony LX300usb turntable
I just received the Sony PS-LX300USB turntable but cannot play sound through the computer speakers. States to setup Playback USB Audio
CODEC which shows working and Recording it shows Microphone USB Audio CODEC which is working. How do I get sound???
Apr 07, 2012 | Sony PS-LX300USB Turntable
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
I have installed the AT-LP60-USB turntable into my computer via USB/ The Audicity program is installed as per the directions. Everything is working well - turntable, Audicity, etc. However, there is no...
You have to listen through the Audacity software. Once you start Audacity, click on the down-arrow on the toolbar next to the microphone symbol and choose Monitor Input. You will need to do this every time you start Audacity.
Nov 07, 2010 | Audio Technica USB Turntable
Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
May 08, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Is there a mac os x driver available anywhere for the sony ps-lx300usb turntable?
You do not need a driver for mac... just plug the usb cable into your mac... go to sound settings in system preferences and set USB to default audio input device... then install audicity... it is free and open source... play your record and hit record in audicity. done.
Feb 06, 2010 | Sony PS-LX300USB Turntable
Trying to install a ion iTTUSB on computer but not
READ your quick start booklet. You need to go to control panel, open sound, there are three tabs- choose playback and make sure that the selected speaker is not USB Audio Codec-choose your speakers. In the Record Tab selcect USB Audio Codec.
Dec 15, 2009 | ION Audio iTTUSB Turntable
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
Sony PS-LX300USB Turntable Logo
4,545 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
