Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence board i have the philips magnavox projection screen tv. its the 60pp9202 set. i have the convergence board to replace the one inside and was wondering if all you need to do is plug and play or does anything have to be soldered? and can you manually adjust the picture after the board has been installed? or do i need to have a tech come out to my house and do this?
  • Philips Master
  • 3,459 Answers
You can just swap the boards - then use your remote to goto the convergence settings screen to reset the blue and red allignments. Its fairly simple.
Posted on Dec 30, 2008
Unable to adjust red convergence much red shadowing
Not able to do auto or manual convergence adjustment.The tv convergence board is dead.The tv convergence board,must be replacing 2 STK convergence ICS and some or all of it resistors too.To fix the convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Philips 60PP9202 60" Rear Projection...
Philips 60pp9202 has volume but no picture
You may a bad ground on the power supply board,and this may include a vertical IC that is having problems. Another thing for me to suspect would be the convergence board is on the fritz. At night sometime remove the back cover and see if you can see the ends of the picture tubes are lit while the TV is on. If they are I would say,yes the convergence ICs are bad. And finally , you may a bad small signal board. This is a small card next to the RCA connections and RF connectors inside this TV. This small signal card is quite expensive to replace. Also, this is my first calculation of errors on this unit. The last answer is my best guess. You will have to decide if you really want to repair this. Once again this small signal board is expensive. Thanks for asking and show a few hands of support.
Nov 10, 2010 | Philips Magnavox 9P6034C 60" Rear...
Having i think convegence board problems with my phillips model # 60pp9202/17F called tv repair guy said it was my convergence ..colors are alll orange and bottom of picture kinda bubbles up can i replace...
Replacing the convergence board will require a complete convergence adjustment. A better solution would be the replacing of the defective convergence IC. This would retain the convergence settings for the set. I'll locate the part numbers and costs and update this later.
Dan
Aug 31, 2010 | Philips 60PP9202 60" Rear Projection...
Having problems with the red and blue convergence. TV image looks like a 3d screen with out the 3d glasses
The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced in the tv convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 21, 2010 | Philips 60PP9202 60" Rear Projection...
Blue & yellow stripe on bottom of screen at first now red and green like 3d
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 08, 2010 | Philips 60PP9202 60" Rear Projection...
Just wondering what the cost would be to add coolant to the green and blue bulbs, and change the computer chips for these 2 as well.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Philips 60PP9202 60" Rear Projection...
My magnavox projection tv has convergence problem.
there are 12 6.8 ohm 1watt resistors in your model. There could be more blown resistors as they often wont show any outward sign of being bad. It could also be the ACS board which is defective if the Resistors are good.
Apr 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
Convergence on Projection screen
More than likely the repair company used cheap chips when they did the repair. The cheap ones fail real quick. Goto the site www.TvRepairKits.com. They have built a kit that you can do yourself. It includes name brand chips and a photo instuction guide.
Dec 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Broken Screen on Philips Magnavox 51mp392h/17
your only chance will be find one at the local repair shops that may have saved some from sets they have scraped out, But they are hard to come by, and phillips have them as no longer available as do most manufactures shortly after that model lines goes out of production. Also try www.craigslist.org as they have chapters all over the world and often people give away dead sets, you may get lucky and find one.
Jun 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
No Video Display, TV is Black. Have all audio and remote functions
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
May 28, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
