Question about ATI All-In-Wonder X800 XT Graphics Card (Open Box Product, Limited Availability, No Back Orders) Graphic Card
My cd/ dvd will not eject or open how do i fix this
I did all the trouble shooting and it says everything is normal also i uninstalled and reinstalled still same problem it will not open. also my sd slot will not read my card how to i clean or repair
  • Anonymous Jan 11, 2009
    dvd inside, but open/close button not working. It stays on 0:00.
    President:
  • 949 Answers
Sounds like your talking about a cd/dvd for a pc, well windows
picks up the device and uses a driver it has you don't need to install anything. Use the emergency open, that is stick a paper clip into the little hole in front and push in just until the door starts to open, this way you check to make sure its not stuck. If you don't have an anti-static strap, touch the case and then unplug the cd player,start windows, shut down, now plug it in and restart, just go to my computer and it should be listed as a drive , if your hard drive is C, then if this is the only drive in it will be d,
Posted on Dec 31, 2008
DVD door will not open to eject DVD
There could be 2 reasons, 1. Hardware issue 2. Software drivers:
Fixing 1: Hardware
Make sure the DVD is fixed properly in your tower ( I am not sure whether you are using a tower or lappi)
The direct solution is to put a pin i the small hole present on your DVD player. That should open the DVD door.
To fix the software part.
>> Try to update the drivers depending on the operating system you are using.
>> Download the latest drivers to check if it fix the issue.
>> Open the My computer >> Right click on the CD/DVD drive and select Eject, this will normally open the door.
Else, try to uninstall the drivers from Device Manager and then restart the PC once, this will reinstall the drivers once again by its own if your Windows is up to date.
Please do get back to us, if that does'nt fix.
Jan 18, 2014 | Zenith XBV243 DVD Player/VCR
Bd rom wont eject
If it does not eject, how does it open?
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 28, 2012 | Computers & Internet
I cant get my dvd drive to eject, and its not recognising that there is a disc in the drive. I do not have a small hole to stick a pin inside as instructed by others as my pc is a PB OneTwo L5710 and as...
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 20, 2011 | Packard Bell Computers & Internet
I have an LH-18A1P installed on my pc. It is installed correctly but the draw will not open. It tries to open when i hit the button or choose the 'eject' option. Any ideas?
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 16, 2011 | Lite On LH-18A1P DVD RW Dual Layer Burner
The door won't open. It keeps getting stuck when I hit the open/eject button
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps don
Feb 25, 2011 | Sony DRX-830U (027242700338) DVD RW Dual...
My laptop is DELL inspiron . Dvd driver is not working properly. After inserting CD/DVD it is not detecting - it shows as " please insert the disc " and it is not ejecting also after giving a...
if its only 8 months old it should be still under warranty so any dismantling you will lose your warranty althought you could run the registry solution i have provided and the antivirus
make sure that the dvd is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
if these fail to fix the problem
hope this helps
dont forget to vote
Feb 19, 2011 | Dell Studio 1537 Laptop
Hi my Pioneer DVDRW DR-TD08HB on my Compaq CQ45 wont read anything. And the drive spins at high speed and wont eject the disc unless I restart then eject it before it starts spinning again. Help!
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 01, 2011 | Pioneer Computers & Internet
HP DVD1040 drive won't open. i went to my computer and right clicked the drive and clicked on eject and it still wouldn't open.
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 14, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
Dvd is not being recognized on my dell studio 1555 laptop
HI
is it powered if yes can you eject it through right click if yes its fine just uninstall your dvd drive from device manager and reinstall it if still dosent work you have to down load the firm ware of the dvd drive from dell sight and upgrade the firware and back to normal.
thanks Dushyantsingh
Dec 05, 2010 | Dell DVD-rom DVD Drive
Won' read discs, won't eject manually or through Eject under DVD drives.
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 14, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
Computers & Internet Logo
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
