Go into the bios and make sure USB is enabled. Restart your computer and look at the screen to see which key to hit to get into the BIOS or System Setup. Look for USB to make sure it is enabled.
If you have a pcmcia slot on your laptop, you can always buy a device that sticks into it that will have usb ports on it for less than $30 - $40. Otherwise you might need a repairman to take the laptop apart and solder new usb ports to the motherboard.
You can reset the password on your Panasonic CF-52 using two different methods.You will need to open up the back cover of your laptop. Now, pull the CMOS battery cell from your motherboard for twenty minutes and then put it back. This should clear the memory. You can also clear your password with jumper settings. Find the jumper on your motherboard named clear CMOS, it has a 3 pin.(1-2-3) Put the jumper in the 2-3 position and then again put it in 1-2 position then check.
If you can reach the motherboard you will find a round button cell. remove it for a few minutes and replace it again. the password would have been undone. Do not use passwords as one tends to forget them sooner or later. Or have one, if you must, that you can remember easily.
will get info and get back to you
give me complete mother board information.
