Question about Microsoft Xbox 360 Console
Help.. My xbox has 3 reds lights
My xbox 360 is flashing 3 red lights makes no noise it opens and closes just fine. i can't play it though....... HELP Im lost with my BOX
  • proskater03 Dec 30, 2008
    i was playing a match in halo 3 and all of a sudden i got the red lights of death
  • 38 Answers
Hello.
This is a common problem from the Xbox 360.
The only way to fix this problem is to call Microsoft or email them. Its something to do with the hardware failure. Its over heated. Their is one way to fix it but temporary.
Its called the towel trick.
First, Unplug your xbox.
Then wrap it around with Heavy towels dont expose anything on the xbox 360. Cover everything.
Then plug in the xbox 360 while the towels are around it. After you do all that you wait 15 minutes. Then unwrap the towel from the xbox 360. It should be very hot. Let it cool down for 2 minutes then plug everything in and it should work.
But I hope this helps you.
Posted on Dec 30, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
3 flashing red lights
Did you try disconnecting it from the power for a few hours?
Apr 18, 2008 | Microsoft Xbox 360 Console
I tried to fix it on my own I need help ASAP
i think u might be getting the red ring of death my xbox did the same thing and a month later i got red ring
Feb 27, 2009 | Microsoft Xbox 360 Console
3 red lights on my x box 360
the dreaded red light...it happened because your xbox is on for long hours at a given time...give some rest and try again if red light goes green play for 3 hours let it cool down for 30 mins... if its dead then i'm sorry
Jan 13, 2009 | Microsoft Xbox 360 Console
Red lights flashing
3 Red Flashing lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 25, 2008 | Microsoft Xbox 360 Console
Was playing Tiger Woods 09 on my 360 when the graphics all of the sudden looked very cheap and generic. I played a few more holes and then shut it off. I tried to turn it back on after about 5 minutes and...
Sounds like the infamous Xbox 360 "3 flashing red LED's" issue, ours did the same shortly before suffering 3 flashing red LED's. If you have one of the original Xbox 360's (without an HDMI port on the back) every single one was built with the wrong solder, so when it gets hot enough the solder melts and your graphics chip gets disconnected.
Is mad as it sounds, run the Xbox 360 for a bit longer until it dies completely because Microsoft have extended the warranty for that specific issue to 3 years! Once you have 3 flashing red LED's you can call the help-line in your country, go through a few diagnostics with them and then (and only then!) the call agent will tell you that as long as your Xbox is less than 3 years old it will be repaired for free.
Microsoft have not widely advertised this and indeed if you try to book service on line it will tell you that you have to pay, even if you click yes to the question "Does your Xbox 360 have 3 flashing red lights on the front?".
However, if you have a newer Xbox 360 message back and we'll go through further diagnostics.
Nick. :)
Nov 06, 2008 | Video Game Consoles & Games
X Box 360
This exact thing is happening to not only me but to also a friend of mine. You will probably notice that the fan kicks on really high and then goes to 2 flashing red lights, this is because the 360 is overheating or thinks its overheating. My friend's 360 starts up with the fan kicked on high and then only plays for a minute or 2, followed by the 2 red lights. If its under warranty send it back to Microsoft, I took mine and my friends 360 apart and replaced the thermal paste with arctic silver, but it kind of only helped a little for mine and not at all for my friends. SEND IT BACK!!!!!!
Aug 30, 2008 | Microsoft Xbox 360 Console
3 red light's
Error Codes XBOX360
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Jan 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
