Question about Electrical Supplies
One of 2 circut resets keeps tripping on our Generac generator
Started on 1st pull, ran great. Turned on necessary breakers, but no 220's. All was fine for about 1/2 hr. then lost power to some areas of house. Found out we needed the reset on circut on generator. This same reset kept tripping. Especially when my husband flipped on the well (220). Then most of what was running on that line ran like 1/4 power or not at all. I finally got it so we had heat & lights again until we got power back. It ran & performed like a trouper about 1 yr ago. But now there's a problem that needs to be addressed, but no idea where to start looking as our manual is no help at all.
  • 334 Answers
If it's tripping a breaker that usually means there is to high of an amp draw on that curcuit.
Are you plugging more things into that particular curciut (or just different but higher amp draw items) than you did last year?
It's also possible that one of the items plugged into that curcuit is wearing out and drawing more amps than before.
If you have an amp meter, plug everything back up just the way it was when you were having problems. Check the main wire going to that curcuit. (right at the breaker)
If your amp draw is greater or nearly the same as the amprating of that particular circuit, then thats your problem.
To many things/to high amp draw on one circuit.
If it is not near the amp rating, and you are getting proper voltage to the breaker, then I would replace that breaker.
Posted on Dec 30, 2008
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
Tip
Generator runs great but produces no power
On Thursday last week I had 220 amp outlet being used and a 110 amp outlet being and overloaded the generator. It turned out to be the reset breakers failed to trip and blew the capacitor. The reset breakers I would suggest replacement after 7 years very easy to do on a 5500 Valsi generator 2010 model still running and now producing electric. And of course use only regular gas non Ethanol.
on Aug 19, 2015 | Electrical Supplies
Hello i just started my 8 kw hole house generater ran greatput my electric water heater on 26 amp draw andsmoke came out exhaust vent shut it down ran again great turned only heater on again took amp
8 kW has a 35 amp breaker on the unit. A typical hot water is 4500 watts at 240 volts = 18.75 amps on each leg. If you are measuring 26 on one side and 19 on the other it should be ok. If it is shutting down you may have a fuel problem or you may need to adjust voltage if it's too low. Which model of 8 kW is it?
Sep 07, 2014 | Generac Guardian Series 8 kW Air-cooled...
Generator circuit breaker keeps tripping
wet plugs,exceeding max load of circut,whatever it is running has a short in it.
Dec 21, 2012 | Buffalo Tools Pro-series 7000 Watt Silent...
Installed a generac 20kw about a year ago, ran fine untill 2 days ago. During a utility outage, generator ran for about 30 minutes and then stopped producing power while still running. All mains were still...
With the engine off, check the exciter brushes and slip rings which supply magnetic power for the alternator winding in the stator. Also, check the motor-to-alternator mechanical coupling. Check the breakers for tripping. To service beyond this point requires a schematic of the alternator, a voltmeter, plus knowledge of what the schematic is telling you. Good luck!
Jul 25, 2010 | Generac Power Systems Generac 5525 20 Kw...
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
I have a Generac MC 5500 portable generator. It
when power tools get old they draw more amperage. 6.8 amps new might be 8 amps. over loading when older.
Apr 16, 2009 | Hammering
Yamaha yg2800i generator will only idle
My guess is that while it was running out of gas the balnket and heater was pulling a load that the generator could not keep up with. Do you still have the manual????????
Mar 25, 2009 | Yamaha 2500 Watt Industrial Inverter...
Generator started, ran briefly, then stopped sending juice
crclarkphd has a problem that sounds like a brush failure. The clunking noise was likely the remainder of the failed brush getting knocked around inside the back end of the generator so you need to take it apart and inspect things closely. Here is a link to a general solution I posted some time ago that may be of help.
Guest jj has a fried breaker in one leg of the 220 outlet. Even though it doesn't look tripped it's failed, check it with an ohm meter.
Regards,
Carl
Feb 18, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
410 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
