Question about Samsung LN32A330 32 in. LCD TV
Component cables produce "no signal" or "check signal cable"
I bought a 32" samsung HDTV along with some component cables to hook my DVD player up to it. i plugged the cables in and got a "check signal cable" notice on my TV. i thought maybe unplugging everything and replugging would do the trick but it just resulted in a "no signal" sign.
  • JstBeHonest May 11, 2010
    Hello...have you fixed the problem yet? Holler back! :)
I had exactly he same problem and it fixed by pressing several times the "source button"
Posted on May 17, 2009
Need to attach dvd/vcr player to cable box and hdtv
DVD/VCR will take inputs of either component BGR RW or composite YWR and will provide either composite or HDMI output. My suggestion is to take the "best output" from the cable box you can and use the HDMI output to your HDTV. This will take the best your cable will offer and give your TV the best signal to use.
Cable box ------ to DVD/VCR ------ to HDTV.
Sep 04, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
Feb 26, 2011 | Bose 3 2 1 GSX System
Hooked up DVD player to 32" Westinghouse HDTV and now all dvd's are in black/white and fuzzy, along with only having 3 total channels! Help!
It sounds like something is shorting out do to an incorrect connection. Make sure you are matching the correct colors if using composite (RCA) or component cables.If you are using composite than hook the yellow for video and red and white for left and right audio. For component cables use the red blue and green for video instead of yellow and use the red and white from the composite cable for left and right audio leaving the yellow unplugged. You should have the cables coming from the DVD players output going to the TV's input. Select the same input on the TV that you have plugged into. If you are using coax cable through the DVD player if it has a tuner than you will need to change the TV to channel 3 or 4 depending on what the DVD is switched to. After you are done with the DVD player be sure to turn the power off so the cable can work properly. I am guessing here since I don't have much info to work with so I hope this helped you.
Nov 29, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Samsung HLR6167 keeps flickering on bright scenes
Try turning off your Energy Saving option. (mine is in Menu --> Setup --> Energy Saving).  See if that helps.
Oct 09, 2009 | Samsung HLN5065W 50" Rear Projection...
Component cables on HDTV not working
have you tried hooking a different video source upto to the tv to make sure it is not the dvd player that is not giving a signal to the tv?  Like an Xbox 360 or anything else with component output.
May 13, 2009 | Samsung TX-R2678WH 26" TV
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | Televison & Video
Mintek 2110 no component video
You need to change the Video out in the menu.
Press set up on the remote
move down to video out and select YUV output
it should now work
Aug 08, 2008 | Mintek DVD-2580 DVD Player
"No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
Feb 07, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Samsung LN32A330 32 in. LCD TV Logo
613 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
