Question about Dacor Millennia ETT365 Electric Cooktop
No responce, breaker is o.k.i have power to unit.
No responce? could this be the touch sensor? or somthing els?
    Problem Solver:
  • 16 Answers
Okay. I just solved this problem, using the suggestions by 'Guest'. Here are some improved tips to troubleshooting.
1. With the power supply ON, spray compressed air into the vents on the underside of the unit. This 'twitched' the contacts on our unit and turned on two of the burners, proving that it was indeed a contact problem.
2. After the unit has cooled down, with all of the 'reminder' lights off. Turn off the main power at the fuse box. You NEVER want to work with an electrical appliance's innards with power being supplied to it.
3. Remove the unit from the countertop. Turn it over and rotate it if needed so that the power supply is not tightly pulling it. Remove the two screws holding the clamp on the power supply wiring.
4. Remove the screws holding the two different boxes together, and the screws holding the main box to the unit. Lift up the two pieces separately, careful not to yank them apart.
5. Remove the ribbon connector from the green computer board. Open the teeth on both sides of the pin and remove it.
6. Using needle-nosed pliers, squeeze on the white plastic posts holding down the upper board. Lift the corners of the board up gently, working with one at a time. Gently remove the board.
7. Look for corrosion or contaminants. Spray the entire lower board clean with compressed air. Spray the entire upper computer board clean with compressed air. Gently replace the upper board onto the 4 white plastic posts.
8. Spray the end of the ribbon connector, then replace it into the upper board. Remove the other end from the main board and spray it before replacing it.
9. Gently touch all the connections, looking for any that have loose contacts. Do not pull on any wires. Spray the entire board, and the adjacent fan, with compressed air.
10. Reassemble the protective coverings and then the power supply clamp.
11. Return cooktop to normal position in counter.
12. Restore main power at the fuse box. The unit should send a series of lights through every bulb, TWICE. If this was the solution to your problem, it is now fixed. :-)
Posted on Jul 07, 2009
Before trying something bigger - take the thing out of the countertop & lay it upside down on a towel. Take apart the 10 or so short phillips screws around the periphery which hold the bottom cover on. Lift the cover up JUST A BIT (several connections between the halves) and you will see a ribbon connector between the circuit board that is the "touch sensor" panel under the glass and the main power switching controls. Try taking apart each end of the ribbon connection a few times and "cleaning" by going off & on the pins. The connector is very similar to that on a computer HD - just less pins. This procedure worked fine for me & brought evertything back to normal!!! Be careful putting things back together that all the high voltage wires are correctly routed and the 2 grommets inside the control box go back into place. This will all make sense when you open things up. Good LUCK! /KRK
Posted on May 07, 2007
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
Tip
Fault Codes Kitchen Aid cooktop
F03 One or more eyes permanently pressed. Recommend that the glas be cleaned and all objects removed.<br /> Unplug the unit for one minute the plug back in if the error still remains after returning power then you will need to replace the touch control module.<br /> <br /> F12 Electronic board and touch module communication error.Unplug the unit for a couple of minutes.Restore the power if the error return then you will need to replace the board connection cable between the touch control module and electronic control. if the error remains replac ethe electronic control board. If the error comes back again replace the the touch pad.<br /> <br /> F13 Internal CPU checksum error.Recommend you replace the touch control module.<br /> <br /> F22 Key sensitivity problem.Turn power off to unit for a few minutes,if the error returns after power is restored replace the touch control module<br /> <br /> F36 Temperature probe hardware error.Recommend that you replace the touch control module.
on Jan 02, 2011 | KitchenAid 36 in. KECC568 Electric Cooktop
What do error codes E51, E52, and E53 indicate?
This link lists the error codes for your cooktop: Needapplianceparts com
Specifically, it's a "sensor break" in your front and center burners.
The solutions they recommend:
* Verify element temperature sensor is correctly connected to the generator circuit board
* Replace element if temperature sensor resistor value is not approximately 1000 ohms (blue wires) at room temperature
* Replace associated generator circuit board
Jan 12, 2014 | Electrolux 30" Electric Hybrid...
My induction cooktop isn't working. When I push any of the touch pads, the numbers flash. There is no E for displayed, only the various numbers I push.
Call the co. And let them guide you thru this. Does your instruction manual give you any help. Hopefully, your board hasn't gone bad.
Jan 18, 2013 | Thermador Cooktops
Diva induction stovetop DDP50/DDP51, central burner touchpad unresponsive
I have the same problem, and resetting the breaker didn't work. There is no child lock on my unit that I can find. Was your issue ever fixed? Does anyone have any other suggestions?
Jan 17, 2012 | Cooktops
The unit light (not the hot surface indicator light) in my GE Profile ceramic cooktop does not turn off although the burners are off.
Hi Danielle, I reviewed the manual for the GE JP350 cook top. Pg. 6 states:
"The UNIT ON indicator light will glow when any surface unit is on."
If the burners are all set fully to the Off position, this lamp should be off. The off position requires that the knob be pressed in to change to Lo, High or any position between (once no longer in the Off position, depressing the knob to change it is not required). If you're able to change the from Off position without pressing the knob, there is an issue with the switch - that may be contributing to the problem.
The cooktop is a 208 / 240 volt appliance. This is the highest voltage in your home. Voltages as low as 50 in the right circumstances can kill, and for this reason repairs must be performed with safety as the first priority. The cooktop sensors have determined that a control is on. If they are indeed off, there is a problem with either the sensor or one (or more) of the controls. You may have luck by locating the circuit breaker or fuse (2 pole 40 amp breaker or (2) 40 amp fuses) and removing power from the cooktop for a minute or two, and then restore power. This would allow the electronics to reset and if a logic problem - it would clear. If there is a hard fault somewhere, the indication would return again.
You should have the cooktop professionally serviced if the indicator fails to extinguish. I hope this helps & good luck!
Sep 16, 2011 | GE 30 in. Profile JP350 Electric Cooktop
Fault Code E7 is up after a small amount of time cooking. power needs to be reset a number of times before it will work again. What does it all mean
Hello there:
this E7 code is referring to a improper temperature between what the oven is set at and the actual temperature is .
So now knowing this you will have to have the temperature sensor or the thermostate repaired or replaced you can also try to unplug or trip the breaker for the appliance for 30 minutes then reapply the power to the unit , these units do have a self reset feature on it but if it doesent then have the appliance serviced by a qualified service repairman
ALSO if you have a warranty with this unit it may be covered with the warranty ok?
best regards Michael
Sep 25, 2010 | Electrolux Cooktops
Top right burner will not work
Your units connections are slowly becoming comprimised. Before our unit went out completely, it went through this phase. A cleaning should fix it.
1. After the unit has cooled down, with all of the 'reminder' lights off. Turn off the main power at the fuse box. You NEVER want to work with an electrical appliance's innards with power being supplied to it.
2. Remove the unit from the countertop. Turn it over and rotate it if needed so that the power supply is not tightly pulling it. Remove the two screws holding the clamp on the power supply wiring.
3. Remove the screws holding the two different boxes together, and the screws holding the main box to the unit. Lift up the two pieces separately, careful not to yank them apart.
4. Remove the ribbon connector from the green computer board. Open the teeth on both sides of the pin and remove it.
5. Using needle-nosed pliers, squeeze on the white plastic posts holding down the upper board. Lift the corners of the board up gently, working with one at a time. Gently remove the board.
6. Look for corrosion or contaminants. Spray the entire lower board clean with compressed air. Spray the entire upper computer board clean with compressed air. Gently replace the upper board onto the 4 white plastic posts.
7. Spray the end of the ribbon connector, then replace it into the upper board. Remove the other end from the main board and spray it before replacing it.
8. Gently touch all the connections, looking for any that have loose contacts. Do not pull on any wires. Spray the entire board, and the adjacent fan, with compressed air.
9. Reassemble the protective coverings and then the power supply clamp.
10. Return cooktop to normal position in counter.
11. Restore main power at the fuse box. The unit should send a series of lights through every bulb, TWICE. If this was the solution to your problem, it is now fixed. :-)
Jan 12, 2009 | Dacor Millennia ETT365 Electric Cooktop
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Power button problem
Without being there to troubleshoot further, the first thing I'd recommend is checking the breaker. It'll most likely be in the breaker panel outside the house... in the BIG panel. This is a 240 Volt unit, so what you'll be looking for is a "dual" breaker. They'll be connected together.
I'll tell you what... here's the easy way to do it. Simply turn off, then turn on all the breakers in the big breaker box outside. Make sure you have all the computers turned off first, though. You might have to reset a few clocks, but that's OK. I'd bet this gets you cooking again. If not, post back.
Oct 13, 2007 | Electrolux 37 in. Designer Series...
Dacor Millennia ETT365 Electric Cooktop Logo
502 people viewed this question
Top Dacor Cooktops Experts
David Payne
David Payne
Marvin
Marvin
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
