Question about SmartDisk FireLite 40 GB Hard Drive
(Smartdisk)firelite 40G external hard drive wont work with vista
Plug in 40G external firelite to USB and it is not recognized all other work fine.
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My computer (Vista) does not recognize my Firelite 40 GB when plugged into the USB port.
try connecting to different usb port. if issue persist check if HDD it self has any issue. same can be checked by connecting it to any other computer.
Apr 12, 2010 | SmartDisk FireLite 40 GB Hard Drive
SmartDisk FireLite XPress 120 GB USB External Hard
Hola!!!
I have this external drive and the truth is that it is very good. But I have a s e doubt that the digital display does not turn me, and I do not know if it is broken or is it because only you connect the USB cable and did not put the current transformer 5Volts. I need someone to help me and tell me what has to be repudiation. Thank you very much!
My Email: @ gmail.com rodolfo.gomez1990
Mar 24, 2010 | SmartDisk FireLite® XPress 120 GB USB 2.0...
USB Device Not Recognized...
try to the laptop firewire port, if works. I didnt find any support for youfirelite drive
Dec 29, 2009 | SmartDisk FireLite 40 GB Hard Drive
External hard drive not recognized
where can i find the software for my smartdisk firelite 160gb
Dec 18, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
Oct 08, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
Computer not recognizing external HD
1st try a different computers make sure its not your Hard drive!
2nd if that works then go to the hard drive maker and download a software driver for it that should fix the problem
Aug 10, 2009 | SmartDisk FireLite 40 GB Hard Drive
External hard drive
Check your device manager for any errors or conflicts.
Dec 16, 2007 | SmartDisk FireLite 40 GB Hard Drive
SmartDisk FireLite 40 GB Hard Drive Logo
185 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
