Question about Toshiba Satellite 2455-S305 Notebook
Toshiba satellite 2455 series unable to reboot windows xp/
Tried the recovery and application cd provided with laptop it say wrong machine and shows windows 98...... what should I try next?
  • beowulf_kg Feb 17, 2009
    My recovery CD says "wrong machine" too
    when I use them to boot.
    I used them successfully once before a few
    years ago.
    I have a Ghost image I made that works, but
    I still want to run a recovery.
    Message from in windows is
    "The Recovery and Application CD is not
    configured to work with your machine
    (Portable PC). This CD is for: Satellite
    2455
    Please use the correct Recovery and
    Application CD."
    I don't think I ever changed the BIOS. I
    have replaced the DVD r-w drive & removed
    the modem. Those are the only changes that
    I can think of apart from added software.
    Problem Solver:
  • 18 Answers
Whats the orig OS installed on your machine? where do you get that recovery cd's ? does it come with the laptop? maybe you've got the wrong OS/ recovery disk with you. Do you have an XP/VISTA installation disk?
Posted on Dec 30, 2008
Toshiba windows 8 reboot system cd
If you have problem booting up ypur computer, try some application which might repair boot files
TestDisk CGSecurity
Aug 07, 2015 | SNWG Toshiba Satellite L875D-S7332...
I need to reboot windows xp on my toshiba satellite laptop
The Toshiba Satellite A10-S169 includes several utilities to improve the performance or security of the computer, and to reconfigure the system's settings. Toshiba Satellites running Windows Vista 32-bit and Windows XP come with the Toshiba HDD Recovery Utility, which allows you to create a recovery CD of your system and applications. The recovery CD will allow you to restore your system and its settings in case your hard drive fails.
Click "Start." Click "All Programs." Expand "Hard Disk Recovery Utilities." Click "Recovery Disc Creator." Select "CD" as the type. Check "Recovery and Applications." Insert a CD into the disc drive. Click "Burn." The Toshiba A10-S169 will begin writing the recovery content to the CD. Follow the on-screen prompts to burn your recovery files to disc. Hope this helps.
Jan 10, 2013 | Microsoft Windows XP Professional With...
My Laptop is Toshiba Satellite A350 series , PATX66HLPBL , PSALWN-00C007 , 39211709K Operating System is Window Vista Home Premium . Now I want to change Operating System Window XP , How to change ? Where...
If you have a Toshiba Recovery CD you may be able to install XP, otherwise :-
You need a Windows XP installation CD together with the installation Product code.
To install Windows XP insert the CD in the laptop and boot up with the CD and follow the screen instructions.
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Apr 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Feb 21, 2009 | Toshiba Satellite M35X-S111 Notebook
To.shiba satellite 2455 series won't reboot
remove the battery then restart the pc... place your installation disk on the drive and try to repair the windows..
Dec 30, 2008 | Toshiba Satellite 2455-S305 Notebook
Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
Aug 11, 2008 | Toshiba A105-S4054 Notebook
Recovery disks aren't Windows XP
Have you tried booting the laptop with the recovery disk already in the CD drive. If the disk doesnt register and start to spin press F12. Should give you option to boot from CD
Mar 07, 2008 | Toshiba Satellite 1135-S125 Notebook
Recovery Problem
  1. Check you are really using the right CDs
  2. Using another computer with a CD Writer and a blank CD, download this file:
toshdmi10.exe
Run the program, it will explain how to make a boot CD which you will use to start your computer and fix the problem that makes it say Wrong Machine.
Once this is done you can use the recovery cd's again.
Nov 15, 2007 | Toshiba Satellite Pro M15-S405 Notebook
Toshiba Satellite 2455-S305 Notebook Logo
325 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
