Home Heater / thermostat isn't working
I have a Carrier 58PAV135-16 Home Gas Heating system. Its also a Carrier home thermostat, and it's been acting up lately. it came with the home circa 1996, and recently It's been intermintedly going out. The  thermostat is set at any temperature above room temperature but it wont come on. I can manually get the fan to come on, but when everything is set in auto mode, I get nothing. Any help? thanks. Cold in Michigan...
  • 7 more comments
  • lupo9 Dec 30, 2008
    Okay. I am going to follow your sequence now. give me a few minutes.
    Okay. so here's what I found out. There isn't an LED code list, but I can tell you what the pattern was. It flashed 3 fast times, then 3 slow times, it repeated this pattern continuously. I followed the process, and after 5 minutes the fan finally turned off with out any other events to report, except the LED now flashes 3 fast, and 1 slow.
    I found code list. You may need to increase font, it was copied from PDF.
    It's a  33
    LIMIT OR FLAME ROLL-OUT SWITCH IS OPEN - If open longer than three
    minutes, code changes to #13. Flame roll-out switch requires manual reset.
    Check for:           - Defective blower motor or capacitor.
    - Dirty filter or restricted duct system.
    - Loose blower wheel.
    - Defective switch or connections.
    - Inadequate combustion air supply (Flame Roll-out Switch or fuse link open).
    - Open Flame Roll-out Switch, or fuse link. Manual reset or replace.
    I just spent 10 - 15 minutes, it never did anything else, except it is still flashing the 1 and 3 LED . I found the code for that as well. Here's the PDF for that sequence:
    LIMIT OR FLAME ROLL-OUT SWITCH LOCKOUT - Control wthree hours. Reset switch or replace fuse link.  Refer to #33.
    Okay. found it, unhooked wires, pressed the red button in center (there was only 1 roll out switch), it didn't make any sort of clicking or a reset sound, (went down smoothly) and turned power back on, flipped fan switch, waited 90 seconds, and BAM, The Flames Kicked on!, that is fantastic, it appears to be working again, temperature is beginning to raise back to normal thermostat setting. I am extremely grateful and appreciative for your assistance in our time of need...I will share my experience with others. Thanks again...Warm again in Michigan.
  • Danny Clark
    Danny Clark May 11, 2010
    If the pic didnt work here is a link to it.
    http://furnaceparts.com/eshop/products/r...
  • Danny Clark
    OK, here is a pic of a rollout switch
    Thats about actual size.
    It is found on the metal housing around the burners.
    You may have more than one.
    There is a little button right in the center.
    Disconnect power, and push the button on each switch. If you feel/hear a click, that is the switch in question.
    Turn power back on and watch again to see what the unit does.
    Rollout switched detect when the burners flame pattern "rools out" into the burner compartment, instead of properly flowing into the heat exchanger.
    Sometimes they just go bad and trip whenever they detect heat.
    Sometimes the system is dirty and causes exess heat build up causing them to trip. And sometimes you have an airflow blockage or draft inducer fan malfunction and the flame DOES rollout and trips the switch.
    Sometimes a strong gust of wind can blow the flame back into the burner compartment as well. This is rare, but it does happen.
    So, reset the switch/es, reset power and lets see what it does.
  • Danny Clark
    Yes, there is a delay for the fan to turn off, and a delay for the system to turn back on after power disconect.
    Without a code list we will have to manualy diagnose the problem.
    While at the unit, turn it back on and wait untill it trys to come on and tell me what happens.
    (again, expect to wait 5 to 10 min before anything happens.)
  • Danny Clark
    Go to the furnace, see if there is a blinking LED light, if so, count the flashes and note the number.
    THEN turn off power, wait 5 min and turn back on.
    After approx 5 more min the furnace should attempt to start. Pay close attention to exactly what it does, and let me know.
    Also, look for the wiring diagram (usually stuck to the panel sometimes in the info packet) for a flash code list. (if you have a flashing LED)
    Correspond the # opf flashes with the code and let me know that also.
  • 334 Answers
It is possible that it may happen again. I reccomend having the burners and burner compartment cleaned, including the Heat exchanger.
If you dont, mind, please rate this solution. All the others were clarificatin requests so we could be sure we found the problem. Now that we found it, It would be great if you could rate the service.
Posted on Dec 30, 2008
What is a two stage furnace?
Two stage heating is a method to make your home more comfortable while reducing your energy. Sound contradictory? Well, that's the truth. Two-stage furnaces are designed to operate like two separate furnaces, maintaining more consistent comfort levels throughout the home. Your furnace or air-conditioner maintenance group will be able to give you more information regarding their working, but I'll explain the basic facts.
A two-stage furnace will always start in the first stage and attempt to meet the heating demand. During mild winter only the first stage will be required that to running at about 60-70% of its efficiency.When temperatures drop, the furnace adjusts itself and enters the second stage to meet the demand for heat within the home. With two-stage heating, a homeowner has no need to keep adjusting the thermostat.
Jan 17, 2014 | Dayton Gas Furnace Heater
Tip
Carbon Monoxide and Heating Systems
Every year there are many deaths that could be avoided by a few simple checks, or the addition of a carbon monoxide detector in the home. The worst thing is that many of those people will have never known that they were under attack by a silent killer.
One of the products of the combustion of any fuel is carbon monoxide gas. The concentration of this gas can vary greatly depending on how complete the combustion process is. Many heating systems will check the combustion process and shut themselves down if the flame becomes too unstable and begins to produce harmful gases. There also are many heating systems still in service that do not check and will produce carbon monoxide gases. If carbon monoxide gas can get into your living environment then you and your family could be at risk.
To reduce the risk of carbon monoxide gas affecting your home, you should have your furnace checked every year. Make sure that the venting system of the furnace or boiler is in good condition. Make sure that the safety controls work properly and are not bypassed. Never bypass the safety controls to get heat even temporarily. Make sure that if you are using an unvented appliance in your home that you follow the instructions by opening a window a bit to give the heater fresh air. Many of these appliances have a oxygen sensor in them to protect you. Make sure to clean this device yearly and if the heater keeps going out and you don't know why, it could be because of oxygen depletion in the room.
Plugged chimneys, bad vent piping, wrong gas pressures, faulty, dirty burners, and many other things can cause carbon monoxide to build up in your home. Be careful to have all of these things checked often. If you heating system is not acting right then you need to have it checked immediately.
One of your best defenses against carbon monoxide is a detector. I like the ones that actually give you a digital read out of the level of the harmful gas in your home. You will find that even your gas range or oven will produce carbon monoxide and it is helpful to see when even low levels occur. The other reason is because the detectors that only give a warning on high levels will often not warn you till the gas reaches deadly levels. You want to be aware of these levels long before the reach deadly levels. This gives you time to get a problem identified and fixed. Also time to evacuate if necessary.
For best peace of mind, spend the money to buy a good quality carbon monoxide detector and then make sure you get it out of the bag and install it. Get your heating system serviced by a professional that can check the combustion process to make sure your heating system is burning cleanly and efficiently. By doing a few simple things you can protect yourself and the ones you love.
on Dec 08, 2009 | Heating & Cooling
I am getting ready to buy baseboard heat for a 800-900 squarefoor open area, old GArage, And I am looking at 3 8' 2500W sections of base board. is this enough. And How much better is the units you have...
First, those of us on FixYa don't sell any products or appliances. Just information.
But to answer your question about electric baseboard heating ... It's the most inefficient and costly heating source you could use. With that said, a lot depends on the cubic footage of the area, as well as how well that area is insulated. This applies for electric, gas or oil heating. You rae not just heating square footage, you're wanting to heat cubic footage (i.e. Width x Length x Height = Cubic Footage). Assuming you have an 8 ft ceiling, the Cubic Footage would be (assuming a 9 ft ceiling) 7200 Cubic Feet. Based on that and if it was my home, I'd be installing a 20,000 - 25,000 Btu Vent-free (Flue-Less) Gas Heater, with built-in thermostat control. It could either be as a Free Standing, Vent-free Gas Fireplace System or simply a Wall Mounted Heater. One is decorative, as well as efficient and the other is simple and efficient. Plus, gas heat is a warm, moist heat that you feel very quickly and it's more comfortable than electric or oil heat. As a matter of fact, Vent-free Gas Heating Appliances are 99.9% efficient. And will work without electricity. Which is great during a Winter power outage. If you currently don't have Natural Gas at your home, then LPG (Liquid Propane Gas) is readily available.
So, by now, you figured out that my preference is gas. I have three Vent-free gas heating appliances in my 3000 square foot home (2-Vent-free Remote Controlled Gas Log Sets in existing wood burning fireplaces & a Vent-free heater in my 2-car garage). Our primary heat source is an electric heat pump. Which doesn't work well, when the temperature reach 32 degrees F or lower. We use the gas heaters only as a supplement heat source or as primary source, if the power goes out.
I hope you'll take a little time to research this, because in the long run, it can save you $$$. Below, is a link to Empire Comfort Systems. They have excellent supplemental and primary heating products in all looks, shapes and sizes. This will give you an idea of what's out there.
http://www.empirecomfort.com/corporate/
I hope all of this helped you. Please let me know. Thanks.
Jun 13, 2011 | Fahrenheat F25426 Electric Baseboard...
Payne AC not working. 1. Thermostat set 68 to AC w/fan on. 2. Breakers and switch near heater are on. 3. Outside unit has 220v but is not running. 4. Fan in heater/Ac unit is not running 5. ...
Dan is this a new system, or has some work on the system (to include the thermostat) been done recently?
Sounds like the thermostat may be wired wrong. From what you describe, the igniter element is coming on, as though you are calling for heating. Do you allow the ignitor to keep going and see if the gas fires off, or are you seeing this and shutting down the system immediately?
If you had the t-stat changed recently, or this is a new system, contact the installing contractor. It may be under warranty.
Sep 03, 2010 | Carrier Heating & Cooling
I have 2 Thermostat's in my home. My heat works well upstairs but not downstairs. My thermostat downstairs won't come on but I unhooked the thermostat from downstairs and tried it upstairs and it worked...
Hi, sounds like you determined the problem is not with the thermostat. That leaves the furnace that serves downstairs. What type heating system do you have?
Jan 13, 2010 | Honeywell Programmable Thermostat Heater
All electric new home. Bought honeywell programable thermostat RTH2308. A/C works but heat will not turn on. This model # is not on their web site.
check to make sure there is a jumper wire on the subase between "rc" and "rh". these designations stand for red/cooling and red/heating.they are used independently if the system has a separate control transformer for heating and a separate one for cooling. they need to be jumpered when one transformer is used to control both modes. your fan "on" switch won't work the fan continuosly if there is no connection to the "r/c" trminal.
on the back of the thermostat there should be a switch you need to select for gas or electric heat. or there are small micro switches that need to be set for your particular application.check your installation papers for details.
these thermostats usually cover a wide range of applications and need to be selected.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
Honeywell heating system
go to the main power box and find the either breaker or fuse that runs the system and turn it off
Dec 25, 2008 | Honeywell Programmable Thermostat Heater
Do the Fahrenheat Hydronic Baseboard heaters work well?
No i would not recomend this model ! if you can stay away from baseboard heat alltogether it is an energy waster!,somthing that moves the air would be a much better choise
Dec 10, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Home heating and thermostat
It is possible the relay on the zone board is bad, You can test the thermostat if you own a voltage meter. It is possible for the thermostat to display and still be bad.
Mar 17, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
1,187 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
