Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Fridge freezes food even though its set at warmest temp
I have a fridge that is this one or very similar model. The control allows you to set the exact temperature in degrees F. I have the fridge set to 38F and the freezer set to 0F. What has happened lately is that the fridge continues to cool and the temperature gets down below freezing 28F or 29F the water dispenser has frozen and my produce is constantly frozen and ruined. I tried changing the temp all the way up to 48F no change, I even tried going down just for the heck of it and nothing. I cleaned the grill on the bottom of the fridge which was the only advice the useless owners manual had. I am pretty handy and can most likely make any repairs, just need to know what im looking for, I really cant afford to pay someone to come fix it or buy a new one, please help! Thanks in advance
  • 1 more comment
  • dsappet Dec 31, 2008
    This refrigerator has the fridge on the top and the freezer on the
    bottom, the cooling of the fridge (top part) comes from the top middle.
    I had read about the flap that can get stuck but there are no appart
    screws or tabs to get into this area. Does anyone know if this fridge
    has a damper or not and how I would access it? thanks
  • Anonymous Jan 09, 2009
    food and produce freezes. 24.8 cu. ft.
  • efkathy Jan 30, 2009
    i have had the same exact problem and had an appliance repair man out here 4 times now - twice with a new motherboard but now our display on the front is not working so we can't control the temperature by adjusting it from the display, and food continues to freeze. Our fridge has been doing this since Day 4 of ownership - and we've been putting our fresh produce in a cooler ever since - that was 2 months ago and Whirlpool/JennAir still refuses to replace the fridge - but sounds like this problem is happening to other people so it's just a badly designed and built fridge. I'll never buy this design or brand again, that's for sure. But if you find a way to fix your problem let me know - we've tried duct tape over the damper and 2 new motherboards but no change.
  • 115 Answers
What it sounds like is either your damper is stuck or your damper motor is bad it will probably be in the top left of your refrigerator side
Posted on Dec 30, 2008
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
My gsh25jsxjss fridge is too cold. the electronic settings do not change the temp in the fridge.... even if I put it on the warmest setting... food is freezing in the fridge area
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, please do check that to confirm the deflector is okay or not....
Hope this will help in solving the problem......
Jan 12, 2011 | General Electric GSH25JSXSS Stainless...
Refrigerator keeps freezing everything, even though the temp is set at warmest
replace the thermostat or if its new model replace or repair control circuit p.c.b
Jan 03, 2011 | Viking Refrigerators
Temperature control doesn't work - FREEZES food
Thermostate control ,I would get new 17 years old if you can sping it .
Nov 26, 2017 | KitchenAid Architect 24.5 Cu. Ft....
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Aug 29, 2009 | Refrigerators
GE Profile Side by Side is getting too cold on the fridge side.
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
My refrigerator freezes my food solid
There are vents that allow the cold air to flow from the freezer to the fridge. If those vents become clogged with ice or fail mechanically, they can become stuck open or closed. The temp adjustment should move the damper in the vents. But if they are frozen open, then the fridge will become too cold.
Thank you for contacting us.Please do rate fixya if you like the solution.
Dec 10, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
231 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
