Question about Dell Dimension 4600 PC Desktop
I want to watch a movie on my pc but it goes into sleep mode 20 minutes into the movie. How can i change the settings. It displays (auto input interjection) how can i change it?
  • 281 Answers
Go to control panel/power settings and change the "turn off monitor, turn off hard disks, and system standby" settings to at least 2 hours. If your screen saver is also a problem, go to control panel/display and the screen saver tab. Adjust the screen saver (or disable it) to prevent screen saver from coming up.
Posted on Dec 30, 2008
  • 585 Answers
Turn off your screensaver from your desktop settings, and modify your power control settings from within control panel. Alternately, you can make a conscious effort to move the mouse every 19-1/2 minutes. I think I would change the settings.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
How to turn off sleep mode in Windows Vista
try going into your control panel and look for your display icon,see if you can do it from there.
Feb 08, 2014 | Dell Inspiron 530 Desktop Computer
Hp pavilion all in one AMD goes to sleep after 1 minute idle then asks for password to open up.. how to extend idle time to 2 hours
What you are experiencing isn't "sleep" mode, it is the screen saver. If you have WINXP, right click on a clear area of the desktop, and select "Properties". When the DISPLAY PROPERTIES window appears, select the "screen saver" tab. Change the "WAIT" time to the time you wish the scrren saver to delay. If you don't want to have to login after a screen time out, uncheck the "On resume, display Welcome Screen" box.
Nov 27, 2013 | HP Black Pavilion 20-b013w All-in-One...
When I start my PC or if the monitor is on sleep mode, on starting the screen goes on & off for about 20 to 3o times before it settles.
go to start-controlpanel-power options-change powersaver to balanced,under change settings u can adjust timings for turn off display and sleep mode.
May 21, 2011 | Computers & Internet
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
My screen keeps going black any ideas?
If it's not showing anything and goes to sleep mode, then did you try to select the proper input from the monitor's on-screen menu?
Otherwise I can't help you unless you are more specific - when does it go black, right away or after 10 minutes of watching a movie for example?...
Oct 26, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
After about 10-15 minutes Vidoe goes out. The
Are you sure it isn't just set to turn monitor after that long, sleep mode, or hibernation? If it set to turn monitor off, then moving the mouse will bring it back up. If it is going into sleep mode, hit the space bar or another key to wake it up.
Aug 18, 2009 | HP FK784AA Pavilion Slimline s3650f...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Dell Dimension 4600 PC Desktop Logo
133 people viewed this question
Alun Cox
