Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
1999 Whirlpool Ultimate Care II
Model# GSQ9310HQO
motor runs however there is no spinning/agitation. probably a broken coupling from what I ascertain from this great site. where can I procure the correct coupling for this model? TIA.
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
SOURCE: Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
The washer fills with water, but no agitation or spin. What's wrong???
Posted on Oct 25, 2008
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
  • 249 Answers
SOURCE: my Whirlpool Ultimate Care II dryer does not heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Jan 02, 2010
washdryman
  • 154 Answers
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Posted on Mar 01, 2010
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II washing machine...no agitation
If this is a Whirlpool manufactured TOP LOADER, a no spin problem can have several causes. Most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem and repair it yourself:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
Read through the link provided and let me know if you have any questions. I have included parts resources and instructions on how to replace each part as well.
If you have questions, please post back and let me know. I hope you find this information helpful.
NOTE: If the model number is correct the part number for a replacement lid switch is 8054980. The part number for the motor coupling is 285753A.
May 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Top loading whirlpool washing machine agitates but will not run during the spin cycle
Some have two belts and one could be off the pulley or if not a coupling on the motor shaft may be cracked or broken.
Jul 09, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Addl Info: Our Whirlpool Ultimate Care II washing maching agitates fine, but will not spin.
The spin tub mounting block is probably stripped on the basket drive. Remove agitator. Now put machine into spin do you see shaft spinning but the tub isnt moving???
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Aug 04, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
