Question about Kitchen Ranges
I have a Spring Air Chiro Comfort Back Supporter Mattress. Classic, Serial # 469235 The switch works in adjusting the head and legs (i.e. up & down), but the toggle switch for the massager is broken (i.e. slides loosely). Is there a replacement ? can I open it up possibly and repair it myself?
  • 1314 Answers
SOURCE: Need replacement broken Leg
1-800-323-9519. thats the number for rival customer service they might be able to hook you up
Posted on Mar 30, 2008
SOURCE: Replacing spring in wheel height adjustment
I just solved the problem. Go to this website: http://www.completevac.com/kirby_schemo_5.html
It will show you where the spring goes (left side inside the ratchet - when you remove the ratchet you will see that it is hollow. That's where the spring goes!) and a good picture of that assembly
Posted on Sep 23, 2008
SOURCE: seat removal 2006 hd flstc got screws loose-but just spring load
If ths is a 1 piece seat ; are all 3 screws loose? If so you may need to pry easily under one of the front 2 screws to get it off
Posted on Jan 23, 2009
  • 10865 Answers
SOURCE: Broken Toggle switch
A toggle switch is a common item. Remove the broken one and take it to a hardware store where they will match it up so u will have the new one u need.
Posted on Apr 29, 2009
SOURCE: wayne dalton classic drive 3018, door goes 90%
wayne dalton classic drive squeaks and binds then stops
Posted on Aug 09, 2009
What do i do when my intex inflatable mattress makes a popping noise and gets bigger on one side?
Sounds like one of the inner chambers is broke, If that's the case you will have to replace the mattress.
Jun 17, 2014 | Intex Comfort Queen Air Mattress - Raised...
Warrenty on serta mattress
When it comes to the Serta mattress collection, there must surely be one that suits almost all individuals. Of course, we are all very different, and the way we like to sleep runs into literally countless different ways. But a Serta mattress is available in many variations, which means that the choice is there for even the fussiest of sleepers.
Serta Mattress Collection
The Sheraton Pillow Top Serta mattress is one of the favorite models in the Serta range. It offers exceptional support qualities with the head to toe coil system which means that no matter how heavy the other sleeper is, there will be no roll together.
Plus Points
-Coil system supports both people without roll together problem
-Fire blocking quality
-Available from twin to king sizes including California King
-At around $1,000, mid range price
-Ten-year warranty
-Pillow top gives firm support but is soft to the touch
-Can be vacuumed occasionally to keep it clean
-Old mattress was taken away as part of the setup service
-Ranked number one on online review sites
Negative Points
-Heavy to handle for one person
-Price may be a little too much for some budgets
-Pillow tops can sometimes wear out before the bed does
-The Serta Perfect Sleeper Ashwood Plush set is probably one of the better-known models in the Serta range. It comes with all the comfort of any other Serta mattress but has a few other good points too. Since it is a firm model with a plush top, this may be a good compromise for couples who have different needs.
Plus Points
-Has patented 'Comfort Zones' for a better sleep
-Increases the circulation in the body
-Has an advanced comfort quilt for more comfort
-Continuous support system to stop roll together
-No pressure point problems
-Fire blocking qualities
-Price in the $900 range for the set
Negative Points
-No removable cover for cleaning
-Some people may find it too firm
-Heavy to move for one person
-The Euro Top Serta mattress is slightly different from the normal pillow top mattresses.
-A layer of cushioning -covers the whole mattress top from side to side, rather like a box top. One obvious advantage is that the mattress -looks more uniform because the pillow top is right along the mattress so there are no undulations.
-It adds some -height to the finished mattress and looks much neater when the bed is made up.
-One great model in this Serta mattress range is the Perfect Day Consideration Mega Euro Top mattress. It has a 3.5 inch top which adds greatly to the comfort.
Plus Points
-Hypo allergenic materials used
-Thicker comfort layer than pillow top
-Memory foam makes it quite comfortable
Negative Points
-Thick and heavy
-Expensive at between $1,700 - $2,300
It would seem that there are a plethora of different styles and comfort levels in the Serta mattress range. For those who like a solid and firm bed, there are several mattress styles that will suit. For those who like a little comfort, try out the plush topped mattresses which offer a little more comfort.
Possibly the only thing that can be concluded is that a Serta mattress must have something that suits most people. Just take some time to work out exactly what is required for an individual model, settle on a price that is favorable, and enjoy a good night's sleep!
Visit the link below to get more useful information -
The Ultimate Serta Mattress Review 2017 Is It Really Good
Dec 28, 2013 | Serta Furniture
What is the best "value" mattress
The best value mattress is that which would provide you a comfort and high-quality sleep without causing any disorders like body and muscles pain.
I would like to suggest you some most used high-quality mattress:
a. Needle and Tuft Mattress
b. Zinus Green Tea Mattress Memory Foam 12 Inch
c. Independently-Encased Coil Mattress Signature Sleep Contour Inch 10
d. Signature Sleep Memory Foam Mattress 12 Inch
e. Mattress 10-Inch Memory Foam Mattress, etc.
If you also want to get these high-quality mattresses, you can buy them directly from Best Rated Mattresses at best deals..
Apr 03, 2013 | Furniture
NEED OPERATING MANUAL FOR INVACARE TURN 2 PLUS MATTRESS PUMP
  1. Use the (M) Auto-Firm Button. Press the Auto-Firm Button to engage auto firm. The Mattress will become firm for nursing procedures. An indicator lights to notify the bed is in Auto-Firm mode. A timer will cancel auto firm in 30 Minutes. Should the nurse be called away, an unattended patient will not be left on a firm surface.
  2. Set the patient weight with the Weight selection buttons (G).
  3. Press the "Center" static Turning Mode button (I).
  4. Place the patient on the bed.
  5. Center the patient on the bed from side-to-side and head-to-foot.
  6. Use a regular pillow under the head for comfort and to prevent the head from rolling excessively.
  7. Raise side rails.
  8. Press the desired Turning Mode button (O).
  9. Press the Full Turn Range button (J).
  10. Set the Turn Interval time with the up/down buttons (L).
  11. If the patient feels the bed is too soft/hard press the up/down Comfort Range buttons accordingly (H).
Jan 09, 2013 | Invacare Air Flotation Mattress Overlay...
The comfort air air mattress pump on the model 833 has quit working it will not pump air I plug it in and it will engage the deflator but the air pump won't engage won't inflate the mattress. I check
If you feel like you can handle it you might try opening up the pump case to actually see the problem area. My guess is either the on/off switch is faulty or, if the motor is burned out, it just won't turn. THere may be brushes in the motor that could be replaced but all of this is speculation until you have a look-see.
Jan 05, 2013 | Heating & Cooling
What are some of the top brands of mattresses?
Some of the more popular and highly purchased mattress brands are: Tempur-Pedic, Sealy, Simmons and Serta.
Jul 25, 2012 | Furniture
What is the best way to shop for a new mattress?
Before you even leave your house, I suggest you understand your needs first. Think about your body and how you sleep. Once you are ready to start testing out mattresses, make sure you go to the store in comfortable clothing. If pajamas were socially acceptable that would be the best! Take your time and lie down on each mattress comparing the feel. Evaluate the level of comfort and support of each mattress you try. Don't be embarrassed to spend several minutes lying on the mattress in the position you usually sleep in. If you pay close attention, you will notice slight differences and start weeding out mattress that you find less comfortable.
I have a 1973 whirlpool washer. I am trying to adjust the back legs on it. It appears to have a spring loaded bar between each of the back legs. The back legs are not adjustable and look to be self...
Disconnect ac/cord,hoses and drain pipe, lay machine down on front side. Inspect the self-leveling bar ***'y and spray liberally with WD-40 if rusty and/or stuck.
Feb 22, 2011 | Whirlpool Washing Machines
Kitchen Ranges Logo
108 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
