Question about Dell Inspiron 1501 Notebook
Dell Inspiron 1501 will not turn back on
I use this computer often for school and I would hardly ever shut it down. I left it on one night and did not go to use it again for about a week. When I went to turn it back on, there is no power what so ever. I tested the battery with the LED lights and all five of the lights went on but I don't know what that means. The AC adapter has power but the computer doesn't have any. What should I do? Is it a problem with the battery? Thanks for the support!
  • Dell Master
  • 32,281 Answers
Hi Melissa,
The battery is OK, when you press the test button the number of LED that are on indicates how much charge is in the battery.
When you plug the adapter into the laptop there should be a LED on the laptop that indicates that it is on main power and charging.
You fault appears to indicate that you have either faulty RAM (memory) or it is not making proper electrical connection with the motherboard.
The RAM is located on the bottom of the laptop under one of the panels. Remove the panel and reseat the memory modules (take it out and insert it again a few times), the reboot your laptop.
If it still doesn't work remove it and take it to your friendly computer shop and get them to test it in another laptop, if it is NBG (no bloody good) then you will need to buy new memory.
Best of luck.
Posted on Dec 30, 2008
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Inspiron 1501 screen won't come turn on
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 11, 2012 | Dell Inspiron 1501 Notebook
Hi when i try to shut down my dell inspiron 1501 it will not shut down
Shut down file is missing. You might have to reformatt it to fix the problem
Apr 17, 2011 | Dell Inspiron 1501 Notebook
DELL 1501 INSPIRON THAT SHUT DOWN AND WANT POWER UP
Short or broken lil jack on the mother board. Needs a professional to look at it.
Oct 11, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1705 9300 17inch shuts down after 15-20 mins win xp
first thing to do is run psa test. turn off laptop. remove batt use ac adapter alone. press and hold on Fn key then press power button once. complete the quick test check if you will be getting error codes like 0142 , 0146 this is hard drive replacement.
Oct 01, 2009 | Dell Inspiron 1501 Notebook
Operating system not found inspiron 1501
Check to make sure the hard drive hasn't come loose. If it hasn't then the hard drive will need to be replaced.
Jun 14, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Shutting down
Hi, Try cleaning the air outlet vents on your Laptop. you can try blowing a can of Air and also chk the power option on your computer control panel.
Jan 31, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
592 people viewed this question
Alun Cox
