Question about Toshiba Satellite A205-S4617 Notebook
No sound on s video to TV
I connected my hp dv4000 laptop to TV via 4 prong s video plug. Works but no sound from TV. I am using a 4 prong plug to a 7 prong on laptop. Are these missing prongs the reason or is a setting?
    Master:
  • 461 Answers
S-Videois video only. You need to a cable to connect the laptop headphone jack to the left and right audio jacks on your TV or receiver.
Posted on Dec 30, 2008
Unable to view pc on tv
With the dv4000, you have the option of using the VGA output (blue connector/port on the side of the laptop), or the S-video output (round connector/port next to the VGA port). Once you have the cable plugged in to the laptop and the TV, press Fn + F7to switch from the laptop screen to the external monitor.
I hope this helps you.
Mar 30, 2011 | HP Pavilion dv4000 Notebook
Can i use 220voltage for hp pavilion dv-2145dx Entertainment notebook?
Check the manufacturer information on the bottom of the AC Adapter. Most likely the INPUT will be
AC110~240V / 50~60Hz which means that you can use it on 220V as it is within the INPUT voltage range. The AC line frequency can be from 50 Hz to 60 Hz. You will need an adapter for the AC plug itself to go from the flat prongs used in North America to the round ones used in Asia/Europe. Also, the adapter will be needed as the wall socket likely will not accommodate the round ground prong that is present on the original three-pronged AC plug that is used for North America.
Feb 19, 2011 | HP Pavilion dv4000 Notebook
I've been trying to use s-video cable to connect
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Mar 06, 2010 | Acer Aspire 3690-2196 Notebook
Is HP Pavilion DV4000 TV Out ready?
The s-video connector is on the right side, next to the back corner. Just plug in the cable and configure it.
Jan 14, 2010 | HP Pavilion dv4000 Notebook
How can i watch downloaded films on my computer on my big screen tv
u can connect your computer to ur TV thru an adaptor(search in google) that can connect to ur PC's display port (the port on ur PC were u conenct ur monitor) the adaptor will have on one side the similar plug as in your monitor cable and in the other end it will have RAS cable plug
or u can use a DIN plug...but ur computer must have a DIN output...
or u can use something like an external TV tuner card box or ADS instant DVD box....
or u can use a convertor box or cable...it will have a 5 pin DIN connector on one end and RAS plug at the other.
Sound is connected from your sound output(the point which has ur speakers connected) plug/output on PC to the sound in of ur TV...again u can use different combination of pin types...RSA or an ordinary sound connector cable
i found this on Ebay...check this out...
http://cgi.ebay.com.sg/PC-Laptop-to-TV-Connector-Watch-Movies-on-Big-Screen_W0QQitemZ150399235227QQcmdZViewItemQQptZLH_DefaultDomain_216?hash=item23047e349b
Dec 31, 2009 | HP Pavilion dv4000 Notebook
I have a hp pavilion ze5000s laptop with a 7 pin s-video port, I also have a flat screen tv with a 4 pin s-video I am trying to use my flat screen as my primary monitor my question is can I use my 4-pin...
you might try a 4pin cable and see if it works.
Not all pins are needed to provide a signal.
If the cable dosnt fit the computer it might be that the Svid port on the computer is actually a Dongle port requiring an additional dongle before the video cable plugs into it.
Mar 16, 2009 | HP Computers & Internet
7pin s-video to 4pin s-video
you have to have and adapter for it. it changes it from a 7 pin to a 4 pin so that your cable can connect to the tv.
not sure how much they are worth but they shouldnt be to much.
hope it works for ya.
Toshiba Satellite A205-S4617 Notebook Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
