Question about Kitchen Ranges
Oven won't work
I own a whirlpool gas range. I preheated my oven to 450 degrees to cook a pizza. When it got to the proper temp I put my pizza in and set the timer for 15 min. Sometime within the 15 min the oven stopped working. I have unplugged and plugged back up and it still won't work. The stove top burners work but the oven won't kick on. Can you give me any idea what I need to do?
  • 115 Answers
Just go ahead and change to glow ignitor it is between 40 and 80 bucks
Posted on Dec 30, 2008
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153992&diagram_id=1251523#d1251523
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
Kenmore Electric oven is not getting up to the proper temperature
Look closely at your knob. I bet it is cracked.
Jun 10, 2009 | Kitchen Ranges
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
Inacurate temp
The follow suggestions apply if you are at sea level, or a bit above. If you are in the mountains, you'll have to compensate for altitude issues. You need an accurate thermometer to be spot on. One way is to use an electronic thermometer. Another is to set the oven to 217 degrees, insert a small pan of water into the oven, with a metal tray or pie tin on a lower rack to catch spills and see if it eventually boils. If the water didn't boil, you can adjust the temperature upward in  5 degree steps (see your owner's manual for details). If you've lost your manual, you may be able to go on-line and get a pdf copy of your manual.If the water does boil, you know your oven is accurate within 5 degrees. You can then proceed to re-do the experiment at 212 degrees, if you wish. Then you may use the data to adjust the oven temperature.
Dec 03, 2007 | Maytag MGR6772 Gemini Gas Kitchen Range
Unable to preheat
You need to replace the temp. sensor. It's not reading correctly. These occasionally go when you use the self clean as the range gets up as high as 900 degrees. Replace it and it will solve the problem
Nov 29, 2007 | Whirlpool SF367 Gas Kitchen Range
Oven temperature fluctuating
Glowworm, Im assuming your model is a 790.78802500. If your husband is handy with a meter have him ohm out the sensor. It should show around 1091 ohms at 75 degrees or room temp. The preheat is programed so that the manufacturer can get the energy effecient label on the range and what ever perks they get from it. It actually should take around another 10 to 15 minutes to reach the set temp after it shows preheated. You can calibrate the oven by setting bake to 550 degrees. Then press and hold the bake pad again for 15 seconds or until a single beep is heard. Now you can adust temps up or down in 5 degree increments up to 35 degrees by using the slew keys. It will show in the display. Once you have the calibration done, press stop/clear. Catriver...post back
Nov 01, 2006 | Kenmore 78802 / 78804 / 78809 Gas Kitchen...
Kitchen Ranges Logo
231 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
