Question about Kenmore 42052
Kenmore 417-42052 loud knocking when final spin
This machine makes a very load knocking sound as it spins at the end of the wash the faster the louder it gets took it bart way apart spings ok shocks ok cement waits all tight
  • 15,935 Answers
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
At the end of each spin cycle it knocks loudly
A Clothes Washer with the complaint of "excessive noise & sssshaking" can typically be a couple of things;
Un-level Washer (Very Likely) - I would level and adjust your legs on your washer appropriately. Make sure when your slighly "push test" your washer, you have no machine movement, rocking or tilting. When the machine is going into the final rinse/spin cycle, the tub can rotate fast and if the washer legs or even the floor is slightly un-level, this can result in your washer to become noisey, shake, etc and can further cause the unit to break-down and no longer spin.
Un-balanced Load (Likely) - Ensure you are loading the washer and distributing the clothes (weight) evenly as this may cause the tub to spin improperly at final spin cycle.
Broken Drum Support/Springs (Likely) - Can be 5" black supports located at inside - top of tub area. Also, springs can also be located at inside bottom rear of machine holding the tub to the rear panel.
-C
Fremont, CA
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 ser. washing machine
HI thanks for your question. it sounds like a faulty motor coupling, which is located on the motor and transmission. replace the coupling.
Oct 14, 2008 | Kenmore 24032\24036 Top Load Washer
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Loud knocking noise at end of spin cycle
    To allow for unbalanced loads and reduce vibration in the floor of the house, the outer tub is suspended by various means. Some machines use a heavy rubber ring, others use spiral springs but either of those can, after a heavily unbalanced load, unhang themselves or in the case of the rubber suspension, the rubber tires and rips.
    If you remove the back panel (10-12 screws) and look inside while pushing the tub side-to-side, you should be able to find the suspension and inspect it with good light.
    Apr 17, 2008 | Kenmore 22622 Top Load Washer
    Loud banging during spin cycle
    please balance your washer and use smaller loads
    Mar 18, 2008 | Kenmore 43052 Front Load Washer
    Spin noise
    If it is making a noise that sounds like a knock you could have a broken mount bolt. Pull the agitator out, remove dispenser or cap, take out inner cap, rmove bolt, agitator should pull out. now you can see the hub and the two bolts that hold the tub onto the shaft. one of the bolts could be broken. If it is go to the hardware store and get new stainless steel bolts and replace both. Also get some blue loc-tite or permatex, or the bolts can come out of the block. Hope this helps.
    Jan 17, 2008 | Frigidaire FEX831CS Top Load Stacked...
    Washing machine
    This sounds like the brakes have gotten some residue on them and are grabbing way too hard. The banging is the tub stopping too fast and the torque from this makes the tub bang into the cabinet. Just one bang at the end of a spin. Is this correct???
    Nov 25, 2007 | Kenmore 23012 Top Load Washer
    Washing Machines Logo
    111 people viewed this question
    Ron Lankford
    Archaeology
    Archaeology
    reliableservice
