Just installed DishNetwork Satellite TV. I have the jumbo remote
I am trying to program my Brookstone for Satellite TV for Dish Network.
I hold down the SAT key on the remote until the red light comes on. Then I key in the codes listed in the remote guide. I try them one at a time. Then, after each try of the code I press the off button. The TV does not shut off. Therefore, I am not able to use the jumbo remote.
Could you give me some advice?
When dealing with satellite tv, you have to set the remote for satellite by setting the correct code for the satellite dish and pressing on the SAT button. Then, you have to set it for sound by pressing on the TV button and placing the correct code for the brank of TV.
In other words, you must set both sound and satellite to be able to control the channels and the sound. This is somewhat awkward for people with disabilities, but it can be taught.
Posted on Dec 31, 2008
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I need to set my dish network remote for my panasonic tv
Hello! My name is Becki, with DISH Network. If you have not yet programmed your remote, here are some steps and codes that should work. If not, please let me know!!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
619
765
700
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Aug 07, 2011 | DISH Network Ir To Uhf Dish Network Remote...
NEED A CODE TO PROGRAM DISH NETWORK 5.4IR REMOTE TO OPERATE PHILIPS HTS3565D
Hello! My name is Becki, with DISH Network. Programming the remote to the TV is a pretty easy process. I have given some codes that should work to program the remote. If not, please let me know!
566
828
824
Becki Barned
Jul 13, 2011 | DISH Network IR Remote Control
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: http://www.dishnetwork.com/supportsection/remote-setup . You can also scan all of the codes to find the correct one: see http://www.dishnetwork.com/SupportSection/power-scan-instructions . Additional remote/receiver manuals are here: http://www.dishnetwork.com/SupportSection/manuals .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Jul 09, 2011 | DISH Network IR Remote Control
How can I program my innovage jumbo universal remote control to my dish network service?
Hi my name isMike Houston of DISH Network and I was going over your post and see you want toprogram the universal remote to the DISH Network. While other remotes may workwith our system the best thing is to use a DISH remote, I will send a link thatgoes with the universal remote; http://www.jumbouniversalremote.net/how_to_program_universal_remotes.html.If you have any questions please e-mail me at Michael.houston@dishnetwork.com.
Jan 11, 2011 | Innovage Jumbo Remote Control
I need the code for my remote control dishnetwork 311
Hello, I hope that this has been resolved for you already, but if not, here are some quick and simple steps to run through! Just follow the link below to get this remote working. Steps 1-5 are to program the remote to the receiver to control channels, and 6 and on is to program the remote to the tv to control the volume. I hope this helps!!!!!!!
http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
Nov 07, 2010 | RCA DISH Network(r) 311 Satellite System
After setting up a new tv, the dish remote will not work with the satellite. what could be the problem?
mbpope
If I understand you correctly, once you installed your new TV, your DISH remote doesn't allow you to change satellite channels. If this is correct, you will need to readdress the remote to the receiver. I have provided a link with these instructions. Included with the link is instructions for programming the remote to your TV.
I hope this helps.
Ray Calo
DISH Network
Nov 07, 2010 | DISH Network IR Remote Control
What are the codes for the dish 103602 satellite?
The codes depend on which device your are trying to program your remote to. you can get this list at www.dishnetwork.com/tech. when you get your 3 digit code. For instance you have a sony Tv, the code is 500, Press an hold the clear tv button at the top of the remote till all mode buttons light up, then release, then enter 500 then the # key and your remote will now work your Sony tv. If you still cant find the codes repost with brand of equipment you want top program.
Nov 29, 2009 | DISH Network IR Remote Control
Satellite dish network codes/innovage jumbo remote controll
Dish Network (0101)
Key 1: 02 5A 2E 09 C9 B6 CD 1C A6 FA AF 34 8D 2B CE 79
Key 2: 4F C1 6C 53 93 15 D3 11 B0 E9 F5 15 35 52 86 04
Dish Network (0106)
Key 1: 04 AD BD 42 87 73 73 64 1F 4A 1F 41 55 4C 4B 69
Key 2: FF 14 A5 BE DA 7B D9 99 73 E3 06 85 34 69 22 45
May 02, 2008 | Televison & Video
Innovage jumbo universal remote code
try this website, you have to scroll down and find "Innovage" on the list and then it will download the pdf of the manual.
http://www.xdiv.com/remotes/
Dec 28, 2007 | Televison & Video
Televison & Video Logo
184 people viewed this question
Top Televison & Video Experts
