Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper does not feed
Each time i try to print, the paper begins to feed through the printer, but seems to only be grabbing on the right side, so gets bunched each time!!! Help?
Http://www.fixya.com/support/t148464-paper_not_feed_grabs_right_side The person before you found a cracker or cheesie or something. I just found a marker lid in mine.
Posted on May 22, 2007
Ref EPSON STYLUS 680 printer paper feed problems ,fails to feed paper but motor runs
try to look on the input tray maybe there are some foreign object that might block the paper,because this kind of printer has a durable pick up roller.
Sep 09, 2009 | Epson Stylus 680 InkJet Color Printer
Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Dell 922 All-in one ink jet printer paper feed
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Dell 922 All-In-One InkJet Printer
Paper feed jams
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
Canon ip6000D
hi,
use good quality paper for printing. clean the feed roller or get the printer serviced from the authorized dealer.
thanks
Aug 09, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp 160
HI this is happening to me right now too-- try this-- I'm not sure if it's going to work-- but it's worth a shot.
On your computer, go to a print menu to print a document.
click on properties
go to maintenance tab
try the quiet/sleep mode
also, try going to custom and slow down the printing allowing for a little extra dry time.
reason I suggest it: my printer is doing the same, it's almost like the auto sheet feeder (only on the right side--why paper is grabbing weird) is grabbing too quickly. When in sleep mode, it seems to slow it down a little. I've also been printing 1 page at a time. I'm not saying this is a permanent fix, but at $50 for a pack of ink-- hopefully if you can't fix it-- it can get you to use up the last of the ink you have incase you decide to get a new printer.
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
I've had this error for the last 2 months and periodically tried to fix it. - I finally read a suggestion to try to push something thicker than a plain sheet of paper through. I cut a side of a manilla folder into a 8.5"x11" and let the printer try to grab it during a copy. After doing it's normal "grab the right side until it's skewed and stop", I continued to try to push it through. I wasn't able to push it to the printing area, but I saw that a piece of something (not much bigger than a bread crumb) came out of the feeder into the interior print area. - I tried another copy, and it was very slightly improved but still skewing and jamming the paper. Suggest unplugging it before performing this...I then lifted the interior piece of plastic (white color for my Pixma MP 150 - which would be located above the paper as it was fed into the print area) slightly to allow any jammed items to come through. Out comes small pieces and then a larger piece of cracker (about the size of 1/4 a cheez-it). Ok I feel dumb, but I'm glad I found something. I picked out the crumbs and did a careful vacuum in the interior and exterior paper feed. Slight warning: The foam bottom below the ink is not secured and will get sucked up by the hose. And note, that I did try vacuuming the intake and interior previously with no improvement. The nozzle on my vacuum is too large to get into the bottom of the exterior intake. - For good measure, I also picked up the printer and turned it upside down and shook vigorously in a couple angles. I saw a couple more small crumbs come out. - My printer is now feeding the paper correctly and successfully made a copy/print.
May 18, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
106 people viewed this question
Clive
Clive
old marine
old marine
