Question about Husqvarna Viking 1
Designer 1 reverse won't select, no light at all
Tried hitting in succession, no luck; also won't reverse for a buttonhole
    Sniper:
  • 87 Answers
The designer 1 has a weakness of the reverse pad (rubber button set) on left side of the machine wearing out and not working. You can try pushing from different angle, or pushing hard, but it most likely needs to be replaced. If you did buttonholes with the buttonhole sesor foot (foot with a wheel and a cord that plugs in), it would automatically size the buttonhole and you wouldn't need to reverse and you can use "FIX" to tie a knot instead of reverse
Posted on Mar 20, 2009
Hi can’t make the button hole big enough using the special one step Pfaff foot . Won’t go bigger than 8mm
It could be that 8mm is the limit for the buttonhole foot. You can try making buttonholes manually with the sewing machine. Not really difficult. Just need to be careful marking the buttonhole and stitching. Recommend practicing on scrap fabric before trying it on the project.
How to Make Buttonhole on Your Sewing Machine Sew4Home (several methods)
Creating Buttonhole Using Sewing Machine
how to sew buttonhole without buttonhole foot Google Search
Jan 26, 2018 | Sewing Machines
Bernina 350 buttonhole - when I hit the reverse button, the machine just keeps stitching backwards. It doesn't stop to do the tck and then go forward again.
Here's a video:
It looks like the Reverse button just needs to be "tapped." On my machine, if I hold the Reverse button too long, it turns into a continuous reverse until I deactivate it.
Bernina 350 16 Buttonholes
If it still won't make buttonholes, you should take it for service. On machines that have the "eye" on the presser foot, the machine needs to be calibrated to use the buttonhole presser foot. Be sure to take the presser foot when having the machine serviced.
Apr 28, 2017 | Bernina Sewing Machines
Singer 1036 1-step buttonhole foot. It will make 1 perfect buttonhole. When I try to make the next one it makes a short buttonhole, never moving forward enough to hit the lever.
Possibly your machine does not make repeat buttonholes and you need to set every time? Are you stitching all the way around before resetting.
Dec 17, 2016 | Singer Sewing Machines
Unable to make buttonhole
did you put the buttonhole foot on?
did you put the button in the buttonhole foot?
did you pull down the buttonhole lever to the left of the needle?
did you choose the buttonhole program you want?
if you answered yes, to all these questions then it would be a good idea to have the machine checked to see why it won't make a button hole
Mar 25, 2014 | Janome Sewing Machines
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
I get a E4 code whan I turn on machine and I can't figure out what is wrong.
Brother Computer Codes E1: Make sure the presser foot is lowered before sewing.
Sep 21, 2012 | Sewing Machines
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
My Singer 2950 buttonhol-er stitches only one side of the buttonhole. It does not reverse and finish the buttonhole. What to do??
Have you pulled down the buttonhole trigger lever at the back of the sewing area? most modern machines have one of these - when you use it with the button hole foot, you'll see the foot has a little piece that sticks out and triggers the lever to begin stitching the reverse bead and bar tack of the buttonhole.
Nov 01, 2011 | Singer 2950 Mechanical Sewing Machine
Buttonhole pattern Wheh I select the buttonhole pattern that I would like I get an error. The machine sews on every stitch but the buttonhole pattern.
Are you using the buttonhole foot when you try? It will look like this.
Also, there is a lever you need to pull down to deploy when stitching buttonholes. It triggers the machine to stop stitching out the side of the buttonhole, reverses then does the other side. Its a little lever up in the head near the pressure foot bar and needle bar. It will touch the sticking out finger on the buttonhole foot to trigger the reverse motion in the programm.
Oct 25, 2011 | Singer CE-200 Quantum Futura Computerized...
Can't complete a manual buttonhole
Don't think of it as a button hole. Run 2 lines of satin stitch (both forward) about 1/4 an inch apart. Bar tack the ends. Voila'! Large button hole.
Mar 03, 2017 | Husqvarna Sewing Machines
Sewing Machines Logo
340 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
