Question about Philips Magnavox 27MS343S 27" TV
Picture screen looks like an hour glass
Wanting to know if there is a setting I am missing, to make the picture fill the entire screen
Sounds like your tv is banjaxt!!!!!! get it repaired!!!
Posted on Dec 30, 2008
Picture has hourglass look and has split screen picture hourglass comes and goes but split screen is continual
If hour glass on conventional set it is either pincussion circuit or power supply---by split screen if you mean folded over top to bottom in the middle that is in the same areas.
Apr 06, 2012 | ESA EF427E TV
I have an IBM ThinkPad running Windows 98 Second Edition used to program older radios so it needs the older version of Windows. The display power on showing IBM Thinkpad full size, but when windows or DOS...
I've seen this before, the main problem is that the resolution is set too low, so it only fills part of the screen.
two ways to solve it.
1. Adjust the resolution to the optimal setting so it fills the entire screen.
2. Find the Picture Scaling option and have it Scale the picture to the entire screen.
To adjust the resolution, now its been a long time since I used windows 98, but I think you got to it by going to your desktop with the background, right click anywhere on the empty space and select properties, now on the window that opens it was the last page, settings I think, you should get an representation of your screen with a resolution lever and color options, pull the resolution lever one point to the right and hit apply and ok, do this until the picture fills the entire screen.
If your laptop has internet connectivity, I could take a look at it over remote support and solve the problem for you.
Oct 23, 2011 | IBM ThinkPad 380 Z (2635HGU) PC Notebook
How can i change the size of image on the lcd screen
Press the Zoom-in button (the one with the magnifiying glass) to zoom in. Press the Zoom-out button (the one with what looks like a part of a checkerboard) to zoom out.
Zooming in lets you look at a portion of an image, zooming out reverses it.
Zooming out also lets you look at thumbnails and navigate around them to select the picture you want. Then you can zoom in to fill the screen with that picture.
If you're looking at a picture full-screen, you can also press up/down on the multiselector to change your view of the picture.
Feb 14, 2010 | Nikon D70s Digital Camera
Expand to full screen. I don't have the manual . I can't seem to get the picture to fill the entire screen.
press menu and move to picture settings and look for format or size if will have either (auto / 16.9 / panaranic / 4.3 displayed change it to full or 16.9
if there is a button on remote with aspect / zoom or format on it press until picture fill screen
Dec 20, 2009 | Samsung LN-T1953H 19 in. LCD HDTV
How to Fix Cracked LCD Screen?
Dear Confused,
Sorry to hear about your phone screen.
There is only one way to make your screen look better, but it will not "fix" the crack. I have done this and sometimes i cannot even tell my screen is still cracked and i didnt have to pay Apple $350 for a new piece of glass.
Here is what you can try:
1. Go to a auto parts store and buy a "Winshield repair kit" for small rock chips that look like a bullseye style chip.
2. CAREFULLY CLEAN THE GLASS WITH ALCOHOL and let dry for 10 minutes. Then heat up the glass of your phone with a hair drier for about 2 minutes so its hot, but not too hot to handle.
3. Then very, very slowly and cautiously, cut the tip of the nipple on the "epoxy/resin" bottle they have in the repair pack and while the phone glass is still hot (you may want to cut the tip of the bottle first, then heat up your phone), gentle squeeze the clear resin into and along the crack in your phones glass....Squeeze the resin directly along the entire length of the crack while attempting to squeeze it INTO THE CRACK...its diffucult, however, the heated glass will **** in the cool resin and actually fill in the crack.
Make sure not to get the resin on the phone or your skin!!!
AND BE PATIENT WHEN applying it.
ALSO, try to do this on a sunny day, because you have to place the glass in direct sunlight, or under a UV light to allow the epoxy/resin to cure. IT WILL NOT WORK UNDER A NORMAL LIGHT BULB. SUNLIGHT Actually works best.
Leave it in the sunlight for at least 1 hour or longer. Then wait another 24hrs before taking a razor blade to scrap off the excess resin that has built up on the glass.
FYI, it the crack to too deep the epoxy will seep thru the glass and this process wont work.
However, if your lucky this should be what your looking for!
Good luck and let me know how it goes!
THanks,
Mark
Jan 02, 2009 | Motorola Mobility KRZR K1 Cellular Phone
The screen flickers into hour-glass figure.
It's the tube going out. You need to replace it. If you want to stay with CRT monitors, you should be able to pickup a used one for around $10.00 on Craigslist.
http://www.craigslist.org/about/sites
Nov 24, 2008 | E-Machines eView 17f3 17" Flat CRT Monitor
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Picture Distortion
you have a convergence problem.. If you understand how this works then you can go into the set find the convergence ic's and replace them and sometimes you need to do some alighnment as well. Its always best though to let a service tech do a job like this as he will have all the proper equipment to adjust and troubleshoot the set Good luck
Mar 30, 2006 | Sony KP-53HS30 53" Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
