Question about SanDisk Sansa Clip MP3 Player
Sansa clip i deleted everything off of it and tryed to turn it on and it says not enough space for music db please free 30mb but i dont know how to do that my computer dont pick it up and i cant find it
  • 8,596 Answers
You need to reformat the player, but you might have to use the volume + method below to force the computer to recognize it.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
5 Suggested Answers
  • 56 Answers
SOURCE: My Sansa 8 gig clip displays this when I turn it
Oops, fixya removed the backslashes from the file path of the file I mentioned in my clarification request. After each backslash, there's a capital letter, so it's easy to figure out. Otherwise, that was meant as a solution.
Posted on Jun 25, 2009
  • 15 Answers
SOURCE: my sansa clip 2gb mp3 is frozen
Wait For The Battery To Die Down Then Plug It Into The Computer And Format It
Posted on Aug 10, 2009
YourZEN
  • 820 Answers
SOURCE: how do I delete 30mbs from my sansa clip the
The player needs free memory to build its database for playlists to playback.
To free memory on your player:
1. Connect to a computer
2. Save a backup of (preferred all) songs to a location on the computer
3. Delete some files off the player to free at least 30 MB memory in the Sansa Clip
Use the manual for how to connect and delete music files.
Clip manual:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Need more help ? Just add a comment in this thread.
Posted on May 22, 2010
  • 18 Answers
SOURCE: When I turn on my
yes the sansa clip has a very small reset button on the top or you can reformat from the pc or the device itself
Posted on Sep 16, 2010
When i try to turn on my mp3 player it says that
Try connecting to a computer and delete from there.
Apr 03, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
Turn's On But Won't Play...
Remove the microSD card, then delete one or more files in the Sansa's internal memory to free up an additional 30MB.
Feb 18, 2010 | SanDisk Sansa e250 MP3 Player
My sansa 1gb says this when it turns on
try freeing up some space on it. if that doesn't work try only putting mp3 files on it.
Jun 30, 2009 | SanDisk Sansa e250 MP3 Player
How to free music db space
my sansa clip will turn on but then it says not enough space for musicdb please free 30mb how do i do that and when i hook it up to my systeam to look at the music files it show nothing please help
Jun 26, 2009 | SanDisk Sansa Clip MP3 Player
My sansa clip 2gb mp3 is frozen
Jun 07, 2009 | SanDisk Sansa Clip MP3 Player
I kept syncn music to my sansa mp3 and now it wont play.
Connect to your computer copy music to a folder and save as whatever name you give it Then format Check the folder with the music in it to see if there is a file thats not MP3 delete it if there is one then replace the music
Apr 12, 2009 | SanDisk Sansa e260 MP3 Player
Dont know how to work it at all
Delete a few files and try again.
May 21, 2008 | SanDisk Sansa e250 MP3 Player
Displays msg. to free up 30 mb -- but can't free up space
Reformat the player is all you can do - you will not be able to download an upgrade that will prevent this from happening in future, b/c the upgrade is not Mac compatible
May 16, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
128 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
