I've had my computer since last Christmas worked fine until a month ago. It got some kind of virus after my Anti Virus expired. Windows Defender notified me of it, I downloaded another Anti Virus program and got rid of it. Next time I try to boot up it turns on.... and that's it. I can get into F8 and various other F buttons. Now it goes straight to system recovery options such as system restore and other things, I try to do the complete system restore and it say Cannot complete, corruption in (C:/). I called Acer and I still had warranty at the time but they won't cover a backup Vista cd. Of course it didn't come with my Acer, which is ********. However you need a credit card or debit card to order the cd, which I have neither. With today's economy, I'm a struggling 21 year old bartender, I can't afford brand new Vista. So now my $600 computer is worthless. =( I'm not even going to ask if anyone knows how to help me because I'm sure with my luck the only thing to fix it is new Vista! But if anyone has any tips on what I should do let me know. Thank youu<3
It may actually be a hard drive failure as the message indicates - either way you will need a Vista disc if you are re-installing or installing to a new hard drive.
Are you sure that it's the driver that's causing it?
I suggest that you run an anti-virus scan. It might have been caused by a virus infection in your computer.
You can also try using RadarSync to scan your computer for driver problems (outdated drivers), then you can google the drivers and install. RadarSync will give recommendations. If you want RadarSync to do all the things for you, then you can buy the license.
Quite often you may have to do the removal and restart your PC. Once you have done that, check your registry to make sure you have removed any traces of flashplayer. Before you edit your registry, make sure you back it up first. Should something go awry, you can go back and recover to the back up registry file. Also make sure you do one product removal at a time and check that the reinstall removed all pieces.
This fault can be caused by so many different things: You should start by tracing back through the recent history of hardware, software, drivers or settings changes to the computer between now and the last time that the computer was working properly to eliminate as many items as possible from the long list of possibilities below so you can isolate the precise cause.
Virus or spyware or other malware infection;Overheating due to insufficient number of internal cooling fans;Dry or insufficient paste between the Central Processing Unit (CPU) and the heat sink/CPU cooling fan;Failed or disconnected CPU cooling fan;Dust blocking input or output of cooling air inside the computer case;Dust blocking the input of cooling air to the CPU heat sink by the CPU cooling fan;Device conflict;Device driver conflict;Corruption of Windows system files;Corrupted Windows Registry during registry editing;Multiple installed anti virus programs in conflict with one another;Multiple installed Firewall problems in conflict with one another;Multiple installed anti malware programs in conflict with one another;Incorrect Firewall settings;Corrupted interrupted or incomplete Windows upgrade setup process;Corrupted interrupted or incomplete Windows repair installation keeping previous files and settingsCorrupted interrupted or incomplete Windows recovery operation;Corrupted interrupted or incomplete Windows Service Pack upgrade process;Corrupted interrupted or incomplete System Restore operation;Corrupted interrupted or incomplete Windows Automatic Updates shutdown configuration process;Corrupted interrupted or incomplete Windows Automatic Updates restart configuration process;Corruption of essential Windows system files by enabling compression to increase HDD free space;Accidental deletion of essential system files;Underpowered Power Supply Unit (PSU);Incorrectly installed Random Access Memory (RAM);Incompatible RAM;Incorrectly installed graphics card;Incorrectly installed expansion card;Internal devices incorrectly connected to the motherboard;Incorrect motherboard jumper settings;Basic Input Output System (BIOS) corruption;Incorrect device IRQ (Interrupt Request) settings in BIOS;Bad hard disk drive (HDD) sectors;Physically damaged HDD;Motherboard solder points short circuiting on a loose screw or a misaligned motherboard mount.
i have acer 4736zg ;that i bought 4 months ago my computer gets heated and shuts down automatically; it works nicely for a week; and gets heated and shut down automatically 3 to 4 times in a day; i am using windows 7 and kapresky anti virus before my computer has windows vista and mcafee antivirus. yesterday my computer showed blue screen death for six times each time i connected net ; i checked the memory status and now its ok but it shutdown for three time in last 12 hours; can u plz help me out
There should be a F key option at start up during the bios side of boot up. Look closely and quickly at the screen when starting up. You should see on that says retstore maybe.
if not just press all of the F keys skiping the ones listed for start up options and bios option.
It's a Vista compatability issue,This is very common and they should have some kind a patch for it soon. Here is a link to read for more details and data recovery options.
ya its probably a virus infection.
If possible run online scans... or install new antivirus software and scan your sys.
If nothing of this is possible or if they are not working..
its safer to reinstall Vista
