Question about Sony D-NF420PS CD Player
Some cd's not reading on my portable cd player
Occasionally I get a cd that does not play on my portable cd player (ie plays briefly then stops, then plays briefly and stops etc. Happens when I skip to another track as well). Its not a fault with the cd as it plays on my computer. My compact disc player will play the majority of cd's fine. My guess is that it is the amount of data stored on the disc being too much for the player, but I really don't know.
fairlane
  • 50 Answers
SOURCE: sony megastorage 300 cd changer
Hi There are many things that can cause your problem, I can tell you the most likely ones, but I recommend you don't take the unit apart, as the mech. in a 300 disk changer is complicated & delicate, and you may just cost yourself alot more money than getting it repaired. The symptoms you sescribe can be caused by failing laser pickup, dirty laser lense (especially if you've done home renvations with drywall), split drive gear that moves the laser on the sled rails, or even a hair or piece of dirt in the gear teeth of that same gear. The unit will play fine, until it hits the tooth where the debris are, then it skips, or jumps back a bit and starts again until it hits the same spot. Also..badly scratched or finger printed disks will cause that, but that is the first thing most people check. I wish it was something you could repair yourself, but my best advise is to take it to a reputable repair shop, and hope it is not a bad laser, as that is a fairly expensive repair. Hope this helps, Good Luck!
Posted on May 04, 2007
SOURCE: Sony MHC-GX450 CD's Skip
Try using a laser lens cleaner. I have the Maxell Thunderon one thats on a Gold CD that you can get at best buy for like $20 or so, seems to work good here on the computer disc drives
Posted on Mar 28, 2008
SOURCE: Disc Read error
I do have the same problem. It all started when I started using Sony discs that has a label to write on one surface. Don't know how to fix it. It is now almost useless!
Raj
Posted on Jul 11, 2008
tech48
  • 624 Answers
SOURCE: CD player skips
Try cleaning the lens. If you can see the lens when you open it to put a cd in, you can clean the lens yourself with a q-tip. Use a very small amount of alcohol or windex, just enough to make the tip of the q-tip moist, and rub it on the glass lens in a circular motion. then use the dry end of the q-tip to dry it off. You can then try another cd and see if it plays good. If so, you are good to go, if not, you probably need a new laser pick up. If it needs a new laser, you may want to just buy a new boombox. The repair will most likely cost as much or more than a new boombox would.
If you are not able to see the lens and clean it yourself, try using a cleaning disc. They do not work as good, but they can help. You run it for about 20 seconds, or whatever the directions state. Then give it another try, see if it plays better.
Those are the only reasonable steps for an end user who is not experienced with repairing these type of units. anything else you may end up trying could just cause more damage to the unit, if you are not experienced with electronic repairs.
I hope this helps, let me know if you need more help.
Dave
Posted on Aug 06, 2008
  • 98 Answers
SOURCE: Sony BDP-S300 won't play any Blu Ray discs
Sounds like a defective Drive
Posted on Feb 06, 2009
How to turn it on to play CD?
Personal CD Players usually have a on/off button or sometime a play and stop button. links below,
press the helpful button
Playing portable CD player
Rio Portable MP3 CD Player
Sony Portable DVD player teardown repair
Top 10 Portable Cd Player
Feb 04, 2016 | Audio Players & Recorders
How to get the laser unit repaired/ replaced on my portable CD player?
Most likely cheaper to replace than repair. The labor cost for such a fiddly repair would be more than a new unit.
Jan 22, 2016 | Magnavox 45 Esp Jogproof Portable Cd...
I have a Craig portable DVD/CD player. It stopped playing sound. What's wrong? Not on mute.
Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote
www.amazon.com/Craig-9...Portable.../B007S71NHM
Amazon.com, Inc.
Rating: 3.3 - β€Ž58 reviews
Amazon.com: Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote, Black ... But keep in mind this player does not provide the highest quality in portable DVD players one can find. .... The remote stopped working within a few weeks.
Craig 10" LCD Portable DVD Player with Swivel Screen and ...
www.qvc.com/Craig-10-LCD-Portable-DVD-Player-with-Swivel-Sc...
QVCThis 10" portable DVD player from Craig comes with everything you need to help keep ... Plays DVD, CD, CD-R/-RW, JPEG; 10.1" diagonal TFT display; swivel screen design..... Couldn't start DVD unless I held down the door or it would stop.
Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD ...
www.walmart.com/.../Craig...Portable-DVD-CD-Player.../33846...
Walmart
Rating: 3.5 - β€Ž18 votes - β€Ž$59.78 - β€ŽIn stock
Buy Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD Player with Remote Control at ... I had one of these portable dvd players but paid over $100.00.
Dec 28, 2015 | Craig Televison & Video
The CD player will rotate but won't play as though it's not reading.
How to Fix your CD Player ' Librarian in Black Blog - Sarah ...
librarianinblack.net/librarianinblack/how_to_fix_your/
Well, if I was a junk pack-rat and still had all the CD players I've thrown away because they stopped ... my portable cd player lens looks to be scarched how can i fix its ... my 3 disk memorex cd player won't play any thing. it was working fine and then allof a sudden it stopped on me it won't even spin the cd to try to read.
No Disc Error, not reading CD error: Repair Sony CFD 112 ...
? 11:35
https://www.youtube.com/watch?v=iEG_u0ogjZI
Jul 23, 2013 - Uploaded by 1000uf
How to troubleshoot and repair CD player not reading disc, table of content (TOC), ... +DeathlyHall0w It's ...
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
If you move the boombox with the audio CD player will it slip, with this model? ... I cannot buy a new boom box ...
Why won't my disks spin? - GameFAQs
Dec 22, 2015 | Audio Players & Recorders
How to fix cd player in boombox - freezes briefly before resuming
IT'S CHEAPER TO BUY A NEW ONE THAN TO HAVE IT FIXED...ESPECIALLY AN EMERSON.
Oct 13, 2014 | Audio Players & Recorders
Kenwood portable cd player dpc-741 skips.
Hello
The skipping happens because the lens is weak,to solve this problem open the cd player so you can see the lens.Clean the lens with cotton wool dabbed in a little methylated spirit(wipe carefully).This should stop the skipping.
If the skipping continues then the lens is too weak to play CD's so it is best that you change the lens of your CD player.
Aug 11, 2010 | Kenwood Audio Players & Recorders
I have a Zennith portable CD-R/RW cd's play just
The problem it´s the motor disc spindle loses velocity and that´s why they can´t read the dvd
May 18, 2010 | Zenith DVP615 Portable DVD Player
Dropped a portable bose cd player and now it doesn't "read" CDs
yeah im sorry but i think your cd player is junk now, most electronics dont survie a drop. did you try a different cd
Jan 11, 2009 | Bose Audio Players & Recorders
Sony D-NF420PS CD Player Logo
37 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
