Question about Fisher and Paykel IWL12 Top Load Washer
Noisy when spinning
When the machine is in the spin mode it emits a noise, sounds as if a bearing is on its way out, can this be repaired at home? We live in the country and servicemen tend to become extremely expensive.
  • 145 Answers
Hello and welcome to FixYa!
When you say "noise like a bearing" do you mean a shreeking/squealing sound? What is more common on that model than a bearing is the water pump will wear out and emit a LOUD "shreeeeeeeeeeek" sound.
If you look under the control panel on your IWL12 there should be a "tech sheet" that will tell you how to put the machine in "diagnostic mode". (I'm 99% sure on that model you hold down the water temperature DOWN button while pressing the power button and it will go into diagnostics) Run the water pump in diagnostics mode and that will tell you if it's the pump making the noise, as the pump can be run by itself in diagnostic mode.
If it turns out to be the pump it is a part number 430235P and you can order one here:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
That site also has service manuals for that model.
Good luck and I hope this is helpful to you.
Posted on Dec 31, 2008
The machine has a noisy bearing when spinning
hi to do this you have to take whole drum out of case take pully off back the drum has screws around holding front and back together when its taken apart you have to knock shaft out from back the inner drum will come out then you can get to bearings fitted in hub these can be tight to get out
Jan 29, 2014 | Hotpoint Aquarius WMA52 Front Load Washer
The washing machine makes a lot of noise during the spin cycle , can it be a faulty bearing?
Sounds very much like it could be.
From the front of the washer, spin the drum by hand, if it feels rough or is noisy, then the bearings have failed.
There should be little or no noise.
Jan 26, 2011 | Washing Machines
Makes a very loud noise when spinning
Sounds like the main bearings have failed, spin the drum by hand, and if it feels rough or is noisy, then the bearings have failed, a major repair!!!!
Nov 23, 2010 | Zanussi ZWF1430W Front Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Very noisy on spin
hello there.....the noise you hear is most likley due to failed drum bearings or something trapped in the drum....test as follows....isolate machine....open the door...test the drum for up and down lift...there should be no movement at all....if all is well here...remove the lid and remove drive belt....spin the drum by hand and listen for any bearing noise (rumble). or metallic sound of something trapped in drum..if all is well here refit the lid temp...Then select spin and start machine...if motor is noisy then the problem is with the motor bearings
regards Sir Galahad
Sep 21, 2009 | Hotpoint WMA64 Front Load Washer
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Mar 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud spin cycle/water leaking
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
Jan 14, 2009 | Kenmore 44102 Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
316 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
