Question about LG Vu CU920 Cellular Phone
My LG Vu says Emergency download after I dropped it in water. And it won't do anything but go to that screen fell into the toilet and when i tried turning it on i saays Emergency Download
  • 10 more comments
  • Anonymous Feb 04, 2009
    i dropped my phone in water and all it says is emergency download. i have tried everything to get it to work and its not working
  • pirate_cheer Mar 01, 2009
    I dropped my LG Vu in the toilet, I dried it and everything. Now sometimes when I turn it on it will work but the touch screen wont respond and other times it just says Emergency Download..
  • Anonymous Mar 05, 2009
    Nu porneste telefonul.Imi cere Emergency Download LG
  • gemattson Mar 10, 2009
    will only show the LG pic like it is just starting up, and it will flash sometimes. no buttons work no other screen comes up. happened to push and hold button below power plug and emergency download came on and won't leave!!!
  • Anonymous Mar 12, 2009
    Same problem - phone got wet and says "emergency download." I tried drying the phone out, then charging it up, and powering it on. It's been almost a day and I'm still getting nothing but the emergency download on the screen. Ugh! I am going to keep trying to dry it out some more but have terrible patience. And now I can't get the back cover off!
  • Anonymous Apr 01, 2009
    My lg vu fell out of my jacket pocket and into the toilet. I dried it out for a day, tried to charge it up and all it said is "emergency download." Took it to Best Buy and a guy there said to buy some white rice, take back off and everything out of phone and let it sit there for quite a whle....the phone may be fried, may not.... Wish me luck!! He also said to try some silica packets, if you have them. Please tell me, CAN THIS PHONE BE SAVED? (It is an upgrade and new 2 year contract....)
  • Anonymous Apr 05, 2009
    i dropped mine in the sand and a wave went over it and it was only in the water for a second but it immediatly went to emergency download and i tried all the solutions and its still stuck
  • greadinger Apr 20, 2009
    My phone worked fine this morning on my way to work. I got to work & cleaned the screen & took the back off & cleaned under the battery - put everything back together & the screens is locked & says "emergency download" I did not get it wet - all wet indicators are white. I called my cell phone provider & they cannot fix it - I have to get a new phone.
  • sunbaby200 May 06, 2009
    I have the same problem, but now mine is charging and turning on for a second. then the screen turns blue and none of the touch screen keys work.
  • Anonymous May 25, 2009
    I dropped it in my cereal bowl.
    and now it is charging but has not done anything.
  • mysonnae May 11, 2010
    I DROPPED PHONE ON GROUND NOW IT SAYS EMERGENCY DOWNLOAD I DID NOT DROP IN WATER SO WHAT IS THE PROBLEM WITH MY PHONE AND HOW DO WE FIX THIS
  • quiru May 11, 2010
    Solution link . . . http://www.LG-Vu CU920.com.
Take out the battery....then put it back in. Do not try to turn on the phone yet. Next plug the phone up to charge. Wait until the charging screen appears and then power the phone. Worked for me.....good luck.
Posted on Jan 19, 2009
I replaced the battery on mine and fixed it. You will have to plug the charger in the phone without the battery, repeat this until the you get different message than emergency download. Then wait until it tells you to place battery in. Then hold power button down until phone turns on
Posted on Jul 27, 2009
Use a hair dryer to dry it out in less than 3 minutes plug it into the charger and without turning it on hit the call button rapidly it worked for me
Posted on Mar 22, 2009
    New Friend:
Okay so i had the same thing show up on my phone. i spilled some liquid on it and it freaked out and did showed this message. So heres what i did and its the only thing i found to work. So take your phone the Lg vu doesnt matter what type, and remove Everything from it. the sim card, the memory card if you have one AND the battery, now plug the phone in to either a USB in a computer or to your charger with out anything in the phone. Turn on your phone like normal and a screen should come up that says insert battery, while the phone is still showing this message put the batter it the phone and it should start back up, if it doeskin turn the phone on like normal again, next it will say insert sim card, do that while the phone is still on, and restart the phone again, now your phone should start like normal, it worked for me i tried everything else online and this is the only thing to get rid of the "emergency error download thing" what ever it said. So thats what it is and your welcome people of the web!
Posted on Jun 28, 2010
I dropped mine in the ocean twice and in the toilet, I dryed everything inside it over with a blowdryer for a half an hour left by the window sill with everything left out of the phone then put white rice in a ziplock bag put the phone in with everything still taken out of it and leave for a couple of days the white rice will absorb all the water out of the phone and help with that problem, then if the Emergency Download appears you can take out the battery put it back in, then plug it in to a computer or the wall charger wait a few seconds and then hold the power up button (red) and it will come one, just don't turn your phone off if you don't have your charger.
Posted on Dec 15, 2009
I had the same problem, it's mostly ok now, but it isn't totally fixed.
Have patience, dry everything again and again. I also tried the red button. continue to reput and take out the battery, sim card and memory card.
It'll be fixed in a couple of hours. However, it might have a couple of buttons that go wrong. (they don't work anymore)
Posted on Jan 02, 2009
It really helps if you put it into rice after you get it wet. Take it apart and then put it in dry white rice!
Posted on Aug 28, 2009
***** Before Sending In Your Phone For Repairs *****
check your battery. this happened to me. my battery was kind of tilted down on the site with the gold contacts. believe it or not, i split a toothpick (about half an inch long) and wedged it in between the lower left edge of the battery and the phone itself in order to push it up into the contacts. boom. works great now. no more emergency download screen. no more insert sim card screen. no more glitches.
ah, modern technology.
-manwich1
Posted on Mar 06, 2010
  • 3 Answers
Dry everything. take the back off, the battery out, the sim card out, memory card (if u have) dry dry dry try again
Posted on Jan 01, 2009
I had a similar problem with my lg vu and all i had to do was take the battery out then put it back in.u should try it although i did not drop it in water i did however drop it and it worked after i took the battery out.good luck!!!!!!!!!
Posted on Jun 19, 2009
Get new phone
Posted on Aug 08, 2009
Best take the phone back to the shop and ask the experts.
It's a pity all pockets don't have zips. It would save phones and other valuables falling out when one sits down or goes to the toilet!
In future sew zips or buttons or press-studs onto pockets to stop mobile phone, keys, money, paper etc falling out, or keep a little airtight bag with vauables in!
Posted on Jul 12, 2013
My lg says its downloading after being a little wet, both phone and battery paper indicators are fine, what is up
Posted on Feb 25, 2009
Nothing happened to my phone. It just stopped working and said "emergency download" I do not have a cable to connect it to PC. I tried all of the above solutions and none of them worked. Any other tips?
Posted on Mar 07, 2010
SOURCE:
On my lg vu, when I unplug the phone or turn it off then back on, it says emergency download. When I manage to plug it into the charger and turn it on its fully functional, but when I unplug it it turns...
I had the same problem when mines got wet, it went away for a couple weeks and then the touchscreen stopped responding. I have ATT and if the little indicator dot behing the battery is anything but white, then your phone is done - they'll try to sell u a new one. I ended up replacing my lcd screen for about $30 and it took me around 20 mins. Mine has been going strong since then. Guides can be found on line (www.lg-vu.com) I think and you can buy the screen on Ebay or online store. I would rate the difficulty to be around an 8 for non techies and around a 1.5 for PC experienced folks.
Oct 16, 2009 | LG Vu CU920 Cellular Phone
I dropped my lg vu in water how do i fix it...it's stuck on the emergency download screen
fill a freezer size Ziplock bag with rice and leave the battery cover off and no battery installed but in the bag with the phone and leave it for 2 days. it may work! let me know..
Sep 30, 2009 | LG Vu CU920 Cellular Phone
Water damage??
take it back for repairs, preferably to an LG phone shop.
Sep 20, 2009 | LG Vu CU920 Cellular Phone
Emergency download message
the water damaged the phone updating system you are out of luck get a new phone and keep your daughter away
Aug 30, 2009 | LG Vu CU920 Cellular Phone
I dropped my Lg vu cu920 in the swimming pool, and I immediately took out the battery and let it dry out, tried the bag of rice, now when I put the battery on the screen says "emergency download" what the...
This same thing happened to me, except it was a toilet. My phone gave me the same message for about a day, but I put it under a reading lamp, battery out too, and let it sit for the night. When I turned it on in the morning it worked okay.
Jun 28, 2009 | LG Vu CU920 Cellular Phone
Dropped in toilet.
you need to bring your to a nearest service center let them open it.
please don't use it or try to power up until it still not fixed to prevent any circuit problems.
thanks,
Jun 25, 2009 | LG Vu CU920 Cellular Phone
I have the same problem!!!! I just dropped mine 2 hours ago!!
http://www.fixya.com/support/r3771170-phone_water_damage
Jun 04, 2009 | LG Vu CU920 Cellular Phone
Screen says Emergency Download
open the screen slot and again plug it ......
May 06, 2009 | LG Vu CU920 Cellular Phone
Emergency download Screen
Put it in rice.
Let it sit. The rice will drain the water out. :)
Nov 11, 2008 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
8,653 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
