Question about Cyberhome DVD Recorder - DVR1600
"no disk" error message
I've only used this about 6 times and I've tried all kinds of disks......all it ever says is "no disk"
Poppo D.
    Problem Solver:
  • 3 Answers
This is not a great solution, but it worked for me. I just purchased a used unit and it was doing the same thing, I cleaned the lens, still didn't change things. I put in a DVD, while it was scrambling around in the load mode, I slapped the unit once or twice, the DVD started to play. This leads me to believe it's an alignment problem with the lens, dunno.
Posted on Feb 19, 2009
Tip
How to check the PC system for errors, repair the damages or check disk.
1.) Go to 'Start'
2.) Press run and type CMD
(You will see a box eg: C:WINDOWSsystem32CMD.exe )
3.) Type CHKDSK , press enter
*CHKDSK is verifying files (stage 1 of 3) You have to wait for a few seconds/minutes.
Then you will get a message 'run chkdsk with /F (fix) option to correct these'.
4.) Type CHKDSK /F . press enter
( *Remember there is a space between Chkdsk and F: chkdsk<space>/F )
Again, you will get a message 'chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
5.) Type Y
You will get a message ' This volume will be checked the next time the system restarts.
6.) Now, exit the box and restart your computer.
It will the check the disk. You will see this on your screen as you restart 'A disk check has been scheduled. Windows will now check the disk (stage 1-5)'
*Note: It will take some time to check your system disk. You need to perform 'check disk' regularly so that you can speed up your PC performance and to repair damages in your system.
* You can try it on any kind of Windows PC.
on Jan 25, 2010 | Computers & Internet
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
Everytime i opened my computer a low disk space message appears. i"ve already tried cleaning up my disk drive but the message continues to pop up
> problem with Barcode Scanners
> low disk space
If your computer has a CD-writer or a DVD-writer, use it, and "burn" some disks containing your files (music?), and then delete the files from your disk-drive.
Then, it's time to purchase an additional internal disk-drive, and install it as a "slave" disk-drive in your desktop computer. It will become the 'E:' drive -- move your files from 'C:' to 'E:'.
Oct 17, 2010 | Computers & Internet
I have a kingston data traveller (pen drive)32 Gb which when i connect to the computer the drive gets detected but when i try to load some data into it, it give me an error message disk not found. When i...
Write protected and disk not found are the typical messages that a pc gives when you try to access a memory stick in which the actual memory chip has died. Nothing more can be done to fix it - it's dead. Junk it.
Aug 08, 2010 | Computers & Internet
Nokia n95 8gb disk error problem
dear, there is a 8gb hard drive in ur phone now its gvng u disk error.to sort out this u have to format ur phone hard drive because a bad sector has been formed due to overloading or virus which can be removed by formatting
Jul 03, 2009 | Nokia N95 Cellular Phone
I cant donwload yahoomessenger 9.0 version
after i submitted my complains i tried loading the yahoomessenger 9.0 again and it loaded there after i clicked on the download button and it no longer gives error message
thanks.
Jan 02, 2009 | Yahoo Messenger
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Dec 31, 2008 | ASUS M2N-E Motherboard
Cyberhome DVD Recorder - DVR1600 Logo
62 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
