Question about E-Machines eMachines Desktop PC
After installing hard drive, monitor, keyboard, mouse not working
I installed a new SATA hard drive on my computer. Emachine T5026. Only 160 Gig. I turn it on but there is nothing on the monitor, the keyboard and mouse do not work.
I went ahead and put in the installation DVD I purchased from eMachines for this computer but nothing happens. After about 10-15 minutes the computer shuts down by itself.
  • 2 more comments
  • imedina1 Dec 31, 2008
    I have checked all connections. Even unpluged and plugged all connectins back in. Also opened another computer I have to compare it to. Many similarities. All looks OK. I know I am missing something I just can't figure it out. I will have to take it in to a shop. I appreciate your help, anyway.
  • SoleAngelus May 11, 2010
    Take the hard drive out again, does the pc boot up as normal?
    Check your connections inside the computer, nothing coming on the screen at boot can somtimes tell you that you connected something up wrong.
  • Aaron Daub May 11, 2010
    Open the case and check to see if all connections are well... connected.
    Scholar:
  • 53 Answers
Have you tried to enter BIOS? Are you able to enter BIOS?? There may be an option you have to hit to enable SATA, and to select the boot device order, which may be messing things up.
Also, remember that STATIC ELECTRICITY is your enemy! Ground yourself when working inside the case.
Posted on Dec 30, 2008
New DQ45EK gives blue screen during XP setup
You may have a bad sector(s) on your hard drive. Best bet is to run a low level format on the drive to clean it up and then do the install.
Mar 30, 2017 | Intel Computers & Internet
Emachine come up where it ask for me to hit f10 or f2 but it wont do anything. My keyboard or the mouse wont work. My emachine is a w3050. Looking for a diagram of how to hook hardrive cd and just to see...
Are you using a wireless mouse or keyboard? If so try using one that you plug in. As for the cd rom and hard drive all you need is one cable for each device hooked to seperate connectors on the motherboard. Ususally the hard drive will be sata which is a red cable and can only go onto one connector on the motherboard. the cdrom is an ide cable(grey usually) and there is a seperate connector for that on the mainboard.
Jun 10, 2010 | E-Machines eMachines Desktop PC
How do you change the hard drive in an Emachine W3609?
how to Install a new hard drive
Do you have the original operating system on CD or DVD? also you need the new HD to be a "SATA" if you do read on
1. unplug all cables from computer (power, Monitor, Mouse, Keyboard, speakers, etc.) try to remove static from body and ground yourself.
2. place cpu on a confortable work table (if possible)
3. on the back of the cpu there is 2 screws that hold the side cover, remove those you may have to do both sides.
4. pull the cover towars the back of the cpu to remove.
5. there you would be able to see if you can remove the tray holding the hard drive or if you can get the hard drive out by itself
6. Unplug the 2 cables on the back of the hard drive (power and data)
7. There should be 2 screws on each side of the hard drive remove them.
8. Now pull the hard drive out of tray (that is a go)
9. insert new hard drive in tray and attach side screws
10. connect data and then power to hard drive (can go in in one direction only).
11. place both side cover (don't forget screws) and make sure the covers go in to the tabs so it would not rattle.
12. connect mouse, keyboard, speaker, monitor and power.
that is it
now you just have to reload your operating system with your cd's turn pc on, insert cd's and restart computer, you may have to press on/off switch to turn it off or ctr+alt+del to restart. if the cd is in it may restart and ask you to press a any key to start from cd if not you have to change boot order from BIoS
if it works for you don't forget to rate
me
thx
Apr 29, 2010 | eMachines W3619 PC Desktop
I had a new hard drive installed on my computer and now my keyboard will not work. My mouse does, but not the keyboard. I temporarily have a wired keyboard hooked up. I can't seem to reset the wireless...
i found 2 computers in the trash. the keyboard and the mouse does not work with a hard drive in it.i cant even get into the bios. when i remove the harddrive. the mouse and keyboard works fine. what could be the problem.
Oct 10, 2009 | Dell Wireless Keyboard Optical Mouse w0147
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Hard Drive
You can replace it with a larger one, just make sure you buy the proper hard drive. If its and IDE hard drive, buy and IDE hard drive, if its an SATA Hard drive, buy an SATA Hard drive. also make sure after you install the new hard drive that you use the operating system cd to format the drive and to install the operating system.
May 04, 2009 | E-Machines T1840 CELERON 1.8 GHz 128 MB 40...
Service pack3 crashed puter - after reinstall machine thinks extra hard drive is a disk drive.
You can get to the BIOS by hitting DEL or F2 at start up.
However, that does not have anything to do with a drive letter.
Drive letter designation is set in
START>SETTINGS>CONTROL PANEL>ADMINISTRATIVE TOOLS>COMPUTER MANAGEMENT>DISK MANAGEMENT.
Hope this helps.
Sep 06, 2008 | E-Machines eMachines Desktop PC
Secondary hard drive
I had this trouble had to reset BIOS to default then it worked but would either recognize IDE drive and not SATA remove IDE SATA was recognized
Its something in the BIOS setup As I do not know your BIOS you will have to check it out with *********** board manual how to do it to setup both drives
Aug 08, 2008 | Intel Motherboard
Emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Jun 16, 2008 | E-Machines eMachines T3830 PC Desktop
Install hard-drive
Sata drives don't have an option to be master/slave like IDE drives, b/c the Sata cable is per device. If the computer's not pulling up the sata drive, open device manager (right click  my computer, properties, hardware tab, device manager) and look for a yellow question mark. You'll have to install drivers for it more than likely.
May 16, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
E-Machines eMachines Desktop PC Logo
330 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
