Question about Apple iPod nano
The i pod is not showing that it is charging
The i pod was missed placed for a long period of time. when we plugged it back into are laptop we are unable to see if it is charging.
  • jerszmom Jan 19, 2009
    My ipod is having the same problem. It is apparently charging, but not showing the charging icon. I get the icon of the USB connection wire that states "Connected - Eject before disconnecting." It is showing this even though the ipod is not fully charged. It's worked in the past. My son let it fully discharge. Could that have something to do with it? We are running the most current software and we have Vista as our operating system.
  • 728 Answers
Since it has been sitting for so long, try doing this: Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge just enough so that it can sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, charging. It should work after letting it sit plugged up to the computer.
Posted on Dec 30, 2008
It will not charge
Try to charge your tablet pc with your laptop or desktop pc.
if it will show the charging then your charger may be out of order.
if it will not charge with your laptop or desktop then your tablet's charging circuit not working.
Feb 15, 2014 | Ematic 7" Tablet Computer
I have HP Pavilion Dv4 1030ee laptop From Last 1 week i have seen that 'plug in but not charging'.my laptop battery is not charging bt working fine on connecting to ac
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 19, 2013 | Computers & Internet
Will a laptop battery become damaged if you use the computer while it is plugged in? I do a lot of photo editing, and leave the computer plugged in for long periods of time, so that it doesn't di
Laptop batteries vary from laptop to laptop. i suggest you Google the Internet for a battery for your model laptop.
Oct 25, 2012 | Acer Ac Adapter Charger For Extensa...
Hi my acer aspire one charg only 79 % not 100% plz solve my problam
Remove the Battery
Sometimes the battery may get dislodged from its chamber due to some movement. This will inadvertently mean that laptop battery will not charge since it is not placed in the right position. Removing the battery and then placing it back in its place properly will show you if this was the reason why the laptop battery was not charging when plugged in. There are a number of connectors that work in tandem when the battery is being charged, and the displacement of even one of these components leads to the laptop battery not charging problem.
Refresh the Battery
Some manufacturers of laptops provide the option of refreshing the battery after it has been used for a period of time, in order to enhance and prolong its life. Read the manual that you received with your laptop and check if this service is available to you. This can be carried out by entering the BIOS or the CMOS setup, and the instructions for this will also be provided in the manual for your laptop.
Replace the Battery
In all likelihood, the reason why yours Acer Aspire One is not charging is that the battery has worn out. Like all electronic components, the laptop battery is also culpable to deterioration over time, and due to this it may not be getting charged at all. In such a situation, you have no choice but to simply replace the battery with a new one. This will solve all your problems and also give your laptop a new lease of life. You may wish to know more about how batteries work.
Aug 18, 2010 | Acer Aspire One PC Notebook
Dell laptop battery has 3 lights flashing when hit battery tester
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Sep 09, 2009 | Dell Latitude D810 PC Notebook
Plugged in not charging
I had the same problem in my laptop and it got solved by taking out the battery and placing back again...
Aug 14, 2009 | Acer ASPIRE 3680-2022 Notebook
"Lost" all USB ports on win xp laptop after plugging ipod shuffle
go into the system restore and choose a date when the usb ports were working then let it go thru its process of restoring. It will restart and then test the usb ports then, if you still can't get them to work then that means the motherboard is bad.
Jun 30, 2009 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
After a period of use the Scooter turns itself off.
sounds like it might be a bad throttle pod, or the brake is overheating. If you can pull the rear shroud off and drive it for a while you can check to see if the brake is overheating. Be careful when checking it because if it is really hot it will burn your fingers. The throttle pod can be checked with an ohm meter but i'm not sure off the top of my head what reading you should get. let me know if you would go that far and i'll get it for you.
Feb 05, 2009 | Pride Mobility Products Hurricane PMV...
Display shows "Not Registered"
1. Remove battery from phone, and unplug from charging cable
2. Unplug Phone base
3. Hold Page button on base and plug it back in. While holding page button wait for in use light to go solid. Once solid unplug base.
4. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
5. Press 0
6. Unplug power from phone pod
7. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
8. Hold the page button on the base and plug it in, Hold page button until the in use light blinks. Let go of page button.
9. Press 9 on your phone. If it says Reg o it is finished. If it says Reg fail try again if it fails twice please call Tech support.
10. Replace Battery
11. Make a test call
Oct 05, 2007 | ClearOne Communications Max Wireless...
Apple iPod nano Logo
180 people viewed this question
Top Apple Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
mac colar
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
