Question about RCA F27628 27" TV
Can't access video input channel
How do we access the video input channel so we can watch dvds . we no longer have the original remotebut do have a working universal remote that says RCA on it but doesn't have the "input" button on it
  • ntremblett Mar 18, 2009
    Exactly the same problem. RCA TV, remote broken. Bought new universal RCA remote, but no input (WHO button)
    Scholar:
  • 63 Answers
I believe you need the original remote to switch the input to video . I found the remote shown at PartStore.com with the original RCA part number 242524 at about $37.00 and also at MCMelectronics.com at around $31.00. There may be other sources also. Good luck.
Posted on Nov 05, 2009
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
Hi, my RCA CRC311 BT turns on my Sharp television, changes the channels, etc, but it won't switch to video mode, even when I hit input. It is an old TV, but I used it to watch videos, dvds and play games...
Unfortunately you will not be able to switch input.
I also have a Sharp, I have tried 5 different universal remotes. None will switch input. I guess that function is not provided properly.
Sep 18, 2010 | RCA RCR311B Remote Control
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
Hi my lg rear projection has lost all tv channels but i can still watch dvds and videos
Use the remote to access inputs, make sure settings are right.
Aug 11, 2009 | Televison & Video
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
How to access the video input channel for my Konka tv?
press menu twice and once + or - volume. and tv will enter in video imput mode.
Jan 27, 2009 | Konka K1398U 13" TV
Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
Input channels
I would try to replace the AV switch IC which directs i/o signals to the tv decoding stage.
Jun 25, 2008 | Sanyo DS24205 24" TV
RCA F27628 27" TV Logo
273 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
