Laptop suddenly shutsdown at startup
When I start up my laptop it loads until it gets to the windows logo, then a system error pops up and says something about LSASS.EXE error message. Thats when it turns off. It just constantly does the same thing over and over....
    Novelist:
    Scholar:
  • 72 Answers
First disconnect anything connected to the laptop not necessary for booting.
Next, when you boot start slowly tapping F8 function key after the BIOS loads, but before you see anything that says Windows.
A menu should pop up. Select Last known good configuration that worked from the menu.
If it still reboots, use F8 to get to the startup menu and select Safe mode.
If you can get to the desktop now in Safe mode, try running a System Restore back to before the problem occurred.
Go to Start > Programs > Accessories > System Tools and select System Restore.
Follow the prompts and select a bold date before the problem began. After the reboot the problem may be resolved, but you may have to re-install any recently added software.
If still no go, boot to the Windows CD and choose to run a repair.
Let me know if you need more help.
Honest1abe
Posted on Dec 30, 2008
Laptop samsung freeze at windows logo startup
Restart with safe mode. Start-Run-msconfig, than uncheck all loading startup programs. (one must be a killer) Restart and go.
Mar 19, 2014 | Computers & Internet
Upon starting my laptop, an error pops up prior to my desktop's icons stating that (Pardon the incorrect formatting) C://documents Cannot be found Then I hit okay and it loads everything fine. Then
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 02, 2012 | Computers & Internet
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Gateway laptop vista unresponsive on startup
go to www.ubuntu.com download the cd image that is suitable for your laptop but USE THE VERSION 8 NOT 9 burn it star your computer with the cd inserted when ubuntu is loaded verify if you can browse your hdd if not your hdd is toasted if yoes you will need to use your recovery disk that came with your laptop but WARNING YOUR RECOVERY DISK IS DATA DESTRUCTIVE if you dont have your recovery disk use any windows install cd (xp , vista or se7en) go to http://www.gateway.com/worldwide/ to get your new driver of your hdd is toasted buy a new one and go to a pc shop to make it replaced
Jun 22, 2009 | Gateway 450ROG Notebook
Windows error
Turn the laptop on.
Just after the laptop logo's have vanished start to press F8 repeatedly until you see an option page pop up.
If the Windows loading screen shows up then you will have to do it again.
Select "Last known good configuration"
Press Enter 2 times.
Apr 08, 2008 | Computers & Internet
Boot Up issue in Laptop
Try booting in safe mode (Tap the F8 key on startup until the menu loads). Let me know what happens.
Feb 23, 2008 | HP Compaq Presario v3000z Notebook
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
