Question about Brother MFC-620CN All-In-One InkJet Printer
Paper not feeding
I cannot print as the paper does not seem to be feeding through. I am not getting any error message, lights flashing, just no printing and a message "data remaining". The printer makes a "whirring sound" like it's going to pick up the paper and print but then it just doesn't. I have tried turning the printer off, opening the back cover, blowing inside the printer.... Can anybody help??
  • curtvprice
    curtvprice Oct 14, 2012
    I am having exactly the same problem with my 6490cw. Great printer, but this is the second one I've had just **** out after a year of use.
  • curtvprice
    (brother mfc 6490cw)
    Genius:
  • 2,985 Answers
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
Posted on May 14, 2007
SOURCE:
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Paper will not feed
My OfficeJet Pro K550 makes sounds like it is getting ready to pick-up the Paper but sounds stops and Printer goes back into the ready mode without printing.
Will you please give me some pointers????
Nov 21, 2007 | HP OfficeJet Pro k550 Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Failed to print
At the head you said 'paper thickness position'and then you seems to have ignored that and did all the other things. Is there an adjustment for paper thickness, a lever perhaps. It does seem to be with the paper feed or paper presence detection. Take a look around, is there something stuck in the paper feed track? Can you have pass a piece of paper through without it rucking up? Do these things see what happens Take a look also at www.fixyourownprinter.com
May 26, 2007 | Canon BubbleJet i550 InkJet Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Brother MFC-620CN All-In-One InkJet Printer Logo
793 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
