Hi,i have Hoover premier 705 4kg model A6578-007 washing machine with me ,though it is old model i purchse it, 1st two cycle have done well, but in next cycle it stuck in between now it doesn't start and water in the drum doesn't drain,kind tell me the remedy
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
I need the lid for hoover premier 710 4 kg.washing machine. model A6578, serial no. 091383
only from hoover agent spares , machines at the dump or washing machine repair shops who may have some as spares
Mar 28, 2017 | Hoover Washing Machines
Model number rh1247b. just purchsed yesterday and took out all bolts as instructed. We done 1 wash yesterday and the drum is making a load squealing noise.
(Could something have ended up in the washer - out of a pocket or similar?) My advice is to contact the vendor or the manufacturer's service centre as the machine is only 1 day old but has managed one wash successfully(?).
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
May 07, 2011 | Washing Machines
Premier w500 the rinse light flashes rapidly and the cycle stops. Any thoughts?
Hi just wondering if you got your problem with your miele sorted out yet as mine has done the exact same thing. Rinse light flashing rapidly and cycle stoped. Have cleaned the filter and re started but no joy.Any luck?
Jan 09, 2011 | Miele Novotronic Premier 500 Front Load...
The door on my hoover easy logic 1100aa washing machine will not open. The wash is complete and there is power???
is this one of the newer HE machines?
the washer may not recognize that the cycle is complete even though you think and see that it has -- can you try running another cycle?
Best regards
Ck
Jan 05, 2011 | Hoover Washing Machines
HOOVER 510 PREMIER WASHING MACHINE ABOVE THE BELT SHAFT THERE IS A PLASTIC COG WHEN THE WASHING MACHINE IS ON WASH CYCLE IT SPINS FINE ONE WAY THEN ON THE REVERSE SPIN THER IS THIS ORANGE LEVER THAT MAKES...
I imagine you've bought a new machine by now? The plastic gearcog is the clutch housing. The arm that clicks is part of the brake lever. On these models, the brake lever is supposed to hold the clutch in place during the wash cycle so that it slips in both directions to get a forward and reverse wash. On spin, the lever moves away releasing the clutch and gearbox brake and allowing the bowl and agitator to spin together. The brake lever wears and allows the gearbox to slip during the wash cycle. When this happens, the clutch housing will "ratchet" past the brake lever tongue. this causes the "clicking" noise in 1 direction.
Oct 17, 2008 | Hoover Washing Machines
Hoover Premier 706 (model A6950) washing machine.When filling water wont shut off.Turn power off water shuts off.If I remove hose from side of bowl and gently blow into it water shuts off.Machine is old...
Inserted flexible piece of thin wire into hose connectioin on outside of bowl and vigoursly wriggled it around - replaced hose and bingo water fills and shuts off and machine operates correctly. Seems like the hose connection was blocked, not a very scientific repair method but seems to have worked. Thanks.
Aug 14, 2008 | Hoover Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Washing Machines Logo
193 people viewed this question
Top Washing Machines Experts
