Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Kitchen aid heavy duty 325 watts mixer won't turn on
Was looking for an adjustment on mixer bowl height. Removed both black plastic screws on each side;obviously nothing to do with that adjustment! I'm thinking the "brushes?" are supposed to go back in a specific direction. Make sense?! Need help!
  • redwing544 Mar 01, 2009
    Also lokking for a way to adjust the bowl height, what is the "brush" several of you are refering to?
    Thanks,
    Dee
On my K5SS mixer, the brushes are aligned with the sliced off corner at 11 o'clock on the left and at 5 o'clock on the right. So the real key is in the suggestion from Mazlynn detailing the use of a flashlight to determine where the little tabs are located inside the brush holders.
Posted on Mar 25, 2009
I had the same problem with my mixer. The solution I found on another forum worked for me. The brushes have to go back in facing the right direction. If you look at the brush, you'll notice that it's a square with one corner shaved off. If you shine a flashlight into the hole where the brush screws in, you'll notice there's a little bump that sticks out of one corner. You need to put the brush in so the notched corner matches up with that little bump. Hopefully that will work for you as well!
Posted on Feb 06, 2009
If the brushes don't match up - the mixer won't work. The brushes each have a little notch. The left notch (looking at the mixer from the front) needs to be at 11 o'clock and the right notch needs to be at 1 o'clock.
Posted on Feb 22, 2009
  • sandy neck Feb 22, 2009
    Sandyneck again, In my previous comment, I made reference to "notches" they are in actuality small triangular bumps. These triangualr bumps need to be at 11 o'clock on the left and at 1 o'clock on the right.
If you take off the big bottom plate (held in by four large screws), you will see that there seems to be no way to adjust the bowl height. Looking inside the column. you will find that the bowl "rests" move within a metal cut-out in the column and cannot go any higher or lower. Sorry.
Posted on Dec 30, 2008
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
I used for 1st time. My cookie dough turned black. Also now have large bump up in middle of bowl.
Take it back to the shop, it sounds like head height adjustment is incorrect from new. I hope you didn't tighten a screw by the inside of the hinge that looked loose. that's your head height adjustment. There is a cone shape at the bottom of the bowl if that's what you think is the bump.
Dec 11, 2015 | KitchenAid Kitchen Aid KSM150PSPK - 5-qt...
The screw underneath the head of my kitchen aid mixer is tight, but the head is still wobbling. It isn't a beater adjustment--I already tried that. The head of the mixer is tilted forward a bit--in
When you have the head lifted up the screw you can see in there from the front in the middle by the hinge is the head height adjuster. You need to set the height correctly now so that FLAT PADDLE just clears the bowl. Unscrew it anti clockwise to raise the head. Once that is done turn the machine upside down on a towel and check that the locking screw on the hinge pin is tight, it\'s right up inside the pedestal.
Aug 08, 2014 | KitchenAid Kitchen Aid KSM150 Artisan 5...
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchen aid stand mixer blades do not reach bottom of bowl
go to youtube type in ajustment on kitchen aids and it will show u step by step hope this helps
Sep 28, 2012 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My KitchenAid Professional 6 mixer has been used about 2 years. Lately it leaves a black trail in my icing/batter/whatever from the finish being worn off the metal beater--the triangular one. The bowl has...
It sounds like you have two problems. First, the black marks are usually because of a reaction between the beater and certain chemicals used in dishwashers. Try washing the beater by hand and scrubbing it throughly to remove any residue. If this works, don't use the dishwasher again. You could also buy a plastic coated beater.
It also sounds like the bowl height needs adjusting. There is a screw just under the head for this.
Jan 08, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I've the 325 watts its 110V kitchen aid and I
You will need a 'step-down' transformer with a rating of at least 500 watts (~500 VA), a primary designed for 220 Volts and a secondary rated at 110-115 Volts. This type will have four terminals or leads and isolates the input from the output.
There is a non-isolating type called an 'autotransformer' which has one winding with a tap (total of three terminals) roughly in the middle. I use this type for certain devices but it is not as safe as the first-described type.
If you are living in a foreign country that uses the ~220 Volt standard, you can sometimes get one on 'semipermanent' loan from the local utility.
Oct 07, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Kitchen aid 300 watt counter mixer model ksm90
no there is no adjustment . worn hinge on the base , no parts made , not that i have ever seen ...... sorry i wish i had better news
Jan 05, 2009 | Hobart A200 Stand Mixer
Kitchen aide mixer
was the bowl snapped in to place.....push down on the back lip of the bowel until you hear it snap
Dec 30, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
278 people viewed this question
Top KitchenAid Food Mixers Experts
Custom Exchange
Custom Exchange
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
